Group2 Arches Fitting Problem
4 replies to this topic
#1 R32Egor
R32Egor
  • 294 posts
Posted 03 May 2024 - 08:50 AM
HI all,
I have fitted my group 2 arches after alot of trials and problems BUT -
There is a gap on the LH front wheel arch that is not there on the RH one. As far as I can see I have fitted them the same.
See pictures -
My questions are -
1 - can I heat the wheel arch up and mould it better or is the gap too big? (fibreglass)
2 - Are the front arches actually fitted in the correct place? are they too far forward?
3 - I have used rivnuts - Should i buy another set and fit them correctly or better (along with more holes in the wings?
Edited by R32Egor, 03 May 2024 - 08:55 AM.
#2 mab01uk
mab01uk
  • 12,254 posts
Posted 03 May 2024 - 09:01 AM
Most aftermarket Mini arches vary in quality and fit and I doubt you have done anything wrong. The gap does not look too bad to me in your photo. I don't think heating a fibreglass arch will help and could make things worse.
Maybe a thicker rubber sealing strip will help take up the small gap?
Phoenix Trim - Aftermarket Mini Arch seals:-
https://phoenixtrim....-seals-81-c.asp
Edited by mab01uk, 03 May 2024 - 09:02 AM.
#3 coopertaz
coopertaz
  • 739 posts
  • Local Club: a-series-magpies
Posted 07 May 2024 - 11:18 AM
looks like l/h arch too far forward but having fitted these myself know they are a pia had to get first set replaced by supplier totally out of shape compared to second set. these fitted but lots of trial and error before i drilled the new front wings. looking at cars at shows very few are exact.
#4 coopertaz
coopertaz
  • 739 posts
Posted 07 May 2024 - 11:21 AM
#5 sonscar
sonscar
  • 2,921 posts
Posted 07 May 2024 - 12:57 PM
The front panel/wing are pushed in?Just a thought,Steve..
