Cooper S Alloy Wheels
#16
Posted 03 May 2024 - 09:53 AM
#17
Posted 03 May 2024 - 09:54 AM
That does look the correct nut, but clearly you'll need longer studs
Posted 03 May 2024 - 10:54 AM
I run those and have never had a problem with them catching.
Just make sure they are fully seated - this will take more torque to pull them in than you would normally tighten a wheel nut to. Unfortunately you can't knock them in, they can be pressed in but its not straight forward.
If they do catch it would be so slight that filing them down enough to get clearance wouldn't affect their strength sufficiently to be a concern.
#19
Posted 03 May 2024 - 12:18 PM
Ideally you would have 2 to 3 threads on the studs coming out of the nut to ensure you have full thread engagement of the nut...especially for safety reasons in the case of securing your wheels which are quiet important part of a car!
Edited by mab01uk, 03 May 2024 - 12:19 PM.
#20
Posted 03 May 2024 - 01:21 PM
https://www.msar.co....heel-studs.html
50mm for the fronts - 7.5" disk setup
60mm** for the rears - spacered rear drums
EDIT : ** the 60mm studs are flush with the tops of the wheel nuts when tightened up. if you (..or the vehicle examiner..) want to see a few threads exposed, then the 65mm studs would be better
2nd EDIT ! : corrected which studs are flush with the nuts
..and these nuts
https://www.minispar...uts-full-set-16
worth noting that as these studs have domed heads they *may* need 1mm or so taking off to clear the brake caliper ( possibly dependent on the calipers being used)
Edited by KTS, 11 July 2024 - 07:47 PM.
#21
Posted 03 May 2024 - 01:28 PM
I see, thanks, did not think clearance was so minimal
are some of them flat heads then, does this only apply to certain size discs .. only asking because I've replaced my studs and now I'm wondering.
can do something about it easily now as it's all still awaiting assembly
Edited by stuart bowes, 03 May 2024 - 01:28 PM.
#22
Posted 03 May 2024 - 01:47 PM
Only on the S type. The correct studs for the S type of fitting also have flat heads.
no such issues on the brakes that use the 8.4” fitting.
#23
Posted 03 May 2024 - 02:00 PM
ah good thanks, mine will be ok then
#24
Posted 11 July 2024 - 08:16 AM
I have the same wheels, had the same issue and used these
50mm** for the fronts - 7.5" disk setup
60mm for the rears - spacered rear drums
EDIT : ** the 50mm studs are flush with the tops of the wheel nuts when tightened up. if you (..or the vehicle examiner..) want to see a few threads exposed, then the 55mm studs would be better
..and these nuts
#25
Posted 11 July 2024 - 09:48 AM
for the longer studs - the dome one can be flattened off with grinding wheel BEFORE you put them in the assembly - and keep a few steel nuts around for pulling the studs into the flange ( can ruin thread of alloy nuts)
The closed wheel nut type I do not like - unless I do the measures myself because of bottoming out before tight. ( I actually have sacrificed a bolt or two - drilled out the enclosed end - so I can see where the threads finish etc
Also as for wheel nut engagement - I thought rule of thumb was like for like eg 5/16 diametre thread 5/16th engagement (or whatever number of threads that is .
Travel safely .. and those wheels look great.
#26
Posted 11 July 2024 - 07:41 PM
Is the 60mm measured below the head, so the total length will be 65mm?
..and these nuts
Stud length is quoted as being from the head face to the end of the thread
http://www.grayston.biz/studspage.htm
Also worth noting that in my previous post I mistakenly said the front studs (50mm) were flush with the wheel nuts when fully tightened - in fact it's the rears that are flush. The fronts have a good 6-8mm exposed
#27
Posted 12 July 2024 - 03:58 AM
#28
Posted 24 July 2024 - 02:16 AM
[quote name="KTS" post="3765255" timestamp="1714742477"]
..and these nuts
/quote]
#29
Posted 24 July 2024 - 07:37 AM
Are these nuts the same height as the stock nuts?
..and these nuts
/quote]
no idea what the stock nut height is, but those ones are 18mm with c.15mm of that threaded
#30
Posted 24 July 2024 - 08:49 AM
Those nuts definitely don't look correct to me...
