Cooper S Alloy Wheels
34 replies to this topic
#1 8mini
8mini
  • 42 posts
Posted 03 May 2024 - 04:26 AM
Just received these wheels from ultralite, is it safe to only get abt half of the wheel nuts threads in there?
#2 gaspen
gaspen
  • 938 posts
Posted 03 May 2024 - 04:47 AM
Alloy wheels usually have thicker material. You have to replace the studs for longer ones
#3 nicklouse
  • 18,574 posts
Posted 03 May 2024 - 06:11 AM
IF those are the correct nut you need longer studs. But ARE those the correct nuts?
#4 8mini
8mini
  • 42 posts
Posted 03 May 2024 - 06:13 AM
Yes, they are the correct nuts as supplied.
#5 8mini
8mini
  • 42 posts
Posted 03 May 2024 - 06:15 AM
I have read on few posts that longer studs from Minispares eill hit the caliper, where can I find the correct studs for disc brake?
#6 Bobbins
Bobbins
  • 1,485 posts
Posted 03 May 2024 - 06:38 AM
Really, I’d double check whether those are the correct nuts …
#7 Stevie W
Stevie W
  • 1,203 posts
  • Local Club: P&SMOC
Posted 03 May 2024 - 06:49 AM
Sorry, but they don't appear to be the correct wheelnuts.
The nut inner edge should have a tapered seat or washer which locates in the taper on the wheel casting. I had a set of those wheels on my Mini a few years back and from memory the nuts where closed in and came with a thick tapered washer.
Cheers, Steve.
#8 Stevie W
Stevie W
  • 1,203 posts
Posted 03 May 2024 - 06:56 AM
According to Minispares website, the nuts you've been supplied with are for the steel Cooper "S" wheels. From memory you will need          C-21A1969  wheelnuts which come with the separate tapered washer.
Cheers, Steve.
#9 Midas Mk1
Midas Mk1
  • 5,774 posts
  • Local Club: S.U.N.M.C
Posted 03 May 2024 - 07:15 AM
Wrong nuts those, look at the taper, completely different.
#10 8mini
8mini
  • 42 posts
Posted 03 May 2024 - 08:01 AM
They are the right nuts according to their Website and the invoice.
There is no room between the studs and the wheel for the C-21A1969 nuts?
#11 Bobbins
Bobbins
  • 1,485 posts
Posted 03 May 2024 - 09:02 AM
As you say, according to the Ultralite website these are the correct nuts. Your photographs though suggest contact between the corners of the nut and the taper which isn’t correct and makes me think the wrong nuts may have been supplied? But yes, you’ll need longer studs.
Edited by Bobbins, 03 May 2024 - 09:09 AM.
#12 timmy850
timmy850
  • 3,327 posts
  • Local Club: MITG
Posted 03 May 2024 - 09:12 AM
Is it the same front and rear? Can you take a photo of the front hub and measure the exisiting stud length from the hub face?
#13 8mini
8mini
  • 42 posts
Posted 03 May 2024 - 09:47 AM
This is the nuts supplied
#14 Bobbins
Bobbins
  • 1,485 posts
Posted 03 May 2024 - 09:48 AM
That does look the correct nut, but clearly you'll need longer studs  ^_^
#15 8mini
8mini
  • 42 posts
Posted 03 May 2024 - 09:49 AM
The front is 7.5" disc brake and i did measured the studs previously and i think it was ard 20mm if i remember correctly.
I haven't try the rear as am waiting to order the wheel bearings.
Edited by 8mini, 03 May 2024 - 09:50 AM.
