Gravitex
6 replies to this topic
#1 Mark2390
Mark2390
  • 18 posts
Posted 02 May 2024 - 02:17 PM
Can you epoxy prime over gravitex?
Have epoxy underneath but going to top coat it.
Thanks for any information
#2 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 15,998 posts
  • Name: Neil
Posted 02 May 2024 - 03:20 PM
Yes you can is the straight answer to this.
But do you need to is another question??
#3 Mark2390
Mark2390
  • 18 posts
Posted 02 May 2024 - 04:58 PM
The gravitex has small crack lines where the seam sealer is underneath so I didn’t want to top coat straight over them
Edited by Mark2390, 02 May 2024 - 05:02 PM.
#4 sonikk4
sonikk4
  • 15,998 posts
  • Name: Neil
Posted 02 May 2024 - 05:15 PM
You could just try brushing over the crack lines with some Gravitex, or some thinned down seam sealer.
I had the same issue when i sprayed Gravitex on my lads car when it was far too cold
#5 Mark2390
Mark2390
  • 18 posts
Posted 02 May 2024 - 05:34 PM
I did mine in a warm unit, nearly killed me with the fumes.
Went over the cracks with another coat but still showed up in a few places.
#6 Avtovaz
Avtovaz
  • 1,197 posts
Posted 02 May 2024 - 05:42 PM
put light coats over seam sealer or it cracks, i found out the hard way too.
#7 gaspen
gaspen
  • 875 posts
Posted 03 May 2024 - 04:51 AM
Epoxy primer is developed to spray on bare metal, which must be sanded before.
I don't think it will work on gravitex ...
