Good morning folks :)
While I was checking the pinout of the relay pack, the ongoing saga to get my friends '94 SPI running again took an interesting turn.
To help "pin" down the issue, I had a look at the diagrams...
Haynes Manual & Forum Diagrams
The diagram (No.21) in the Haynes Manual is the same in both the copies of the manual I own, "1969 to Oct 1996" and "1969 to 2001" .
The redrawn diagram from the forum (link) is the same except for what I think is a mistake?
forum-diagram-mistake.png 16.47K
2 downloads
The load output (Pin 87) of the Main Relay looks to be connected to the load source (Pin 30) for the PTC Relay and the Starter Relay, as well as "P7" (12v+) of the large connector.
I think what's happed is the wire join has been shifted over?
Going by the Haynes Manual and from what I've read in the "SPI Relay Pack Functionality" thread, I believe it should look like this?
Otherwise anything downstream of the Load Output (Pin 87) of the Main Relay would already have 12v provided to by P7 of the large connector.
forum-diagram-ok.png 16.84K
3 downloads
The Relay Pack In My Friends Car
What I found after pinning out the whole pack was very strange! I ended up redrawing the diagram in colour to help me try and get my head around it.
The biggest source of confusion is shown by the "Teal" line within the relay pack.
in-car.png 256.67K
0 downloads
Here's a summary of what's different:
Load Source (Pin 30) Of The Fuel Pump Relay
- Diagram: Connected to P6 of the larger connector and shares continuity with load source (pin 30) and switch+ (pin 86) of the Main Relay.
- In Car: The load source (pin 30) of the Fuel pump relay, is solely connected to P1 of the large connector.
Large Connector P1 (Brown/Pin Wire)
- Diagrams: Provides power to the Ignition Coil, Fuel Purge Valve and ECU.
- In Car: Solely connected to the ECU.
Large Connector P8 (Brown/Pin Wire)
- Diagrams: Provides power to the Throttle Stepper Motor and the Switch+ (Pin 86) of the O2 Relay.
- In Car: Provides power to the Ignition Coil, Fuel Purge Valve, Throttle Stepper Motor and the Switch+ (Pin 86) of the O2 Relay.
Relay Pack Current Theory
My current theory is that someone has replaced the PCB of the Relay Pack with one which didn't come from a Mini. Looking online I think some Land Rovers used a variation of them.
Relay Pack Solution
One option I have considered to replicate the original intent of relay pack.
Move the Brown/Pink wire from P1 to the currently unused P3.
Then splice in to the Brown wire going to P6, and add a new wire/pin to the now free P1.
ECU Pinout - MNE101040
The other thing I wanted to check...
Both the loom on the car and the Haynes Manual have the Brown/Pink wire from P1 of the Relay Pack going to Pin 28 of the ECU and a Black ground wire to Pin 29 of the ECU.
The Diagram from the forum has this flipped, Black on Pin 28 and Brown/Pink on Pin 29.
Summary
There is a lot of info there! So if I've worded something poorly please let me know and I'll try and clear things up.
I will also post some pictures of the Relay Pack housing and PCB later.
As always, any help would be greatly appreciated.
Edited by NotMyMini, 01 May 2024 - 10:40 AM.
