Help On Aligning A Pillar Stiffeners
3 replies to this topic
#1 CBJ805T
CBJ805T
  • 438 posts
Posted 30 April 2024 - 04:12 PM
Hi, The next job on the list, is fitting the A pillar stiffeners, before fitting the inner wings.
By holding the panel against the A pillar, it seem to have a 'natural' location, but as this panel, and the A pillar, we're not present when I got the car, I'm not sure how critical the positioning is.
I can see it has holes for the door hinges - do I need to attempt to fit the door, get the gaps correct, and use this as a guide or can I assume any tweaking of the door hinges, can we done by fettling the holes, at a later stage?
https://www.amazon.c...cPSBFIoidGTS6gV
https://www.amazon.c...heh2StALfAKL3ip
Thansk
Chris
Edited by CBJ805T, 01 May 2024 - 07:24 AM.
#2 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 15,998 posts
  • Name: Neil
Posted 30 April 2024 - 05:46 PM
Chris, i would try and install the door and gap as much as you can although this will be difficult but doable i feel.
Yes the stiffener does sit quite naturally within the A post but as you say you had nothing to go with to start with makes things somewhat more difficult.
#3 KTS
KTS
  • 2,390 posts
Posted 30 April 2024 - 05:58 PM
..a different issue, but the same approach
https://www.theminif...ight/?p=3578799
#4 CBJ805T
CBJ805T
  • 438 posts
Posted 10 May 2024 - 11:31 AM
Thanks Both
