Floor Grommets
2 replies to this topic
#1 Mark2390
Mark2390
  • 18 posts
Posted 08 April 2024 - 07:01 PM
How many floor grommets are needed for (total refurb)?
And does the battery box have them?
I’m going to gravitex or similar the underside should I fit grommets first or after?
#2 ClassicBRG
ClassicBRG
  • 76 posts
Posted 09 April 2024 - 08:54 AM
My battery box didn’t have grommets.
I fitted them after doing the underside (putted tape on the inside on the holes).
#3 stuart bowes
stuart bowes
  • 1,942 posts
Posted 09 April 2024 - 11:20 AM
my floor had 11 holes, plus 3 in the battery tray plus i think two in the spare wheel well?
I welded in all the main floor ones and the boot ones I'll use rubber grommets
I don't know what others might recommend but just for neatness I'd probably do the gravitex first, then clean up a few mm around the edge of each hole, and fit the grommets with some sort of mastic or sealant in the edges because obviously minis love to suck up water
Edited by stuart bowes, 09 April 2024 - 11:22 AM.
