Old Tyres That Hold Air
9 replies to this topic
#1 stuart bowes
stuart bowes
  • 2,644 posts
Posted 08 April 2024 - 11:41 AM
bit of a long shot probably
is there anyone in the Essex area ideally close to dagenham / romford / ilford who has a set of 4 old tyres they were going to throw away or willing to sell for like £20-30 or so (have you just put a nice new set on and wondering where you were going to ditch the old ones ?)
not concerned about tread or cracks as long as they hold air
basically I want something to put on the old rims that I can use just to push the shell around on once I've built up the subframes and brakes etc
then when the build is complete I'll commit to refurbing the rims and putting fresh rubber on
Edited by stuart bowes, 08 April 2024 - 11:43 AM.
#2 Verderad
Verderad
  • 413 posts
Posted 08 April 2024 - 03:52 PM
I have 4 12" tyres just removed due to age.  All held air, good tread, couple of cracks.
I'm probably as far west away from Essex as you can get being just past Cardiff.
I travel up to Warwick Coventry weekly if that helps with transfer.
Yours if you want them.
Darren
#3 stuart bowes
stuart bowes
  • 2,644 posts
Posted 08 April 2024 - 05:31 PM
just a little out of my range I'm afraid! but I appreciate the offer, thanks anyway
I'm starting to think about ringing around local 2nd's tire places and see what I can rustle up, just thought maybe worth taking a punt on here first you never know
#4 Midas Mk1
Midas Mk1
  • 5,853 posts
  • Local Club: S.U.N.M.C
Posted 08 April 2024 - 06:35 PM
Might be cheaper finding a scabby set with tyres on, have the factor cost of tyre fitting if you can’t do it yourself, also the fact most reputable tyre fitters wont fit perished tyres due to liability.
#5 stuart bowes
stuart bowes
  • 2,644 posts
Posted 08 April 2024 - 06:48 PM
you may well be right on that, I do have a local tyre place that know me well though I could probably explain why and they'd do it for me
but yeah, I have also been looking on ebay for cheap sets of wheels, a lot of them say 'tyre's need replacing' though and what I don't want is to end up with a set that just constantly go flat because that's what I already have
#6 Quinlan minor
Quinlan minor
  • 1,388 posts
Posted 08 April 2024 - 07:31 PM
Just a thought: Why not stick a set of tubes in the tyres you have?
Pull the valves out, break the bead on one side, slip in the tube, valve through the hole.
Pump it up, job's a good un.
#7 DeadSquare
DeadSquare
  • 3,382 posts
Posted 08 April 2024 - 08:46 PM
I screw the 4 castors from a scrap supermarket trolley to the corners of a wooden pallet, but I have got a smooth concrete floor.
#8 stuart bowes
stuart bowes
  • 2,644 posts
Posted 08 April 2024 - 09:07 PM
oh that stage is fine I'm thinking more of when it's painted underneath, subframes on with suspension and brakes etc, just messing around with the upper / outer bodywork prep
it would just be a lot easier to move about on the dollies if if has wheels on it rather than being stuck on axle stands
and yet I don't want to buy the proper tyres too soon and waste potentially a year or so of lifetime just being sat around
#9 RichB
RichB
  • 10 posts
Posted 09 April 2024 - 07:48 AM
Mine is still on a dolly with subframes and suspension all in place. I'm only going to put it on wheels when the engine goes in, which will be the last big thing. I too like the ease of moving around the garage.
#10 1984mini25
1984mini25
  • 8,850 posts
Posted 09 April 2024 - 10:52 AM
I had similar issues a few years back when looking for a scabby set of standard steel wheels with tyres to put on the car during winter hibernation. The mini still runs the standard 12” steels with hub caps, but it’s the tyres flat spotting I’m more concerned with.
I eventually found a set with reasonable tyres (reasonable age, decent amount of tread and no cracks) locally for £40.
I never checked at the time, but when it came round to fitting them I then found 3 out of the 4 all had slow leaks from the valves (old and perished) And yes I did find out after I’d fitted and left the mini for a few days.
A local tyre place wanted £15 each just to change the valves, but were reluctant due to the age of the tyres.
So I found a tool sold by Halfords for £20 (have to order online) were you can change the valves without removing the tyres, and bought the replacement valves off eBay.
Just looked, don't think Halfords still do it, but its Laser tools number 5540.
Edited by 1984mini25, 09 April 2024 - 10:55 AM.
