Knock Knock
20 replies to this topic
#16 Lplus
Lplus
  • 848 posts
Posted 11 August 2024 - 08:31 AM
ok knocking is still there, noticed when greasing my nipples (well cars obviously ) that there is no bolt on  the bracket securing the manifold pipe. Amyone know what sort of size it should be... would any short  10mm bolt do the trick...?.. want to secure this before any further investigations
Presuming you mean the bracket from the bottom of the downpipe to the bracket on the gearbox output cover.  Usually 5/16 UNF.  So 8 mm will also fit.
#17 mrmeds
mrmeds
  • 239 posts
Posted 11 August 2024 - 10:10 AM
thanks , thats the one !
#18 mrmeds
mrmeds
  • 239 posts
Posted 18 August 2024 - 07:18 PM
replaced missing bolt.... kniock still there... :(  :(
it seems worse when engine gets warm.....and  comes when power is put on quickly and taken off quickly. Sometimes its a multiple knock , lile almost a rattle.
Cant get any movement with the engine and have replaced top and bottom bushes anyway. Had engine mounts replaced in jan 2023
any ideas ,,,,, could it be something loose in engine bay .... have noticed the throttle cable was loose , and was able to hit against pipe from brake servo, so have fastened it down. Surely it cant be something that simple,,,,, Haven't had a chance to  test since noticing
#19 Quinlan minor
Quinlan minor
  • 1,143 posts
  • Local Club: LSMOC
Posted 18 August 2024 - 08:22 PM
I'm not familiar with the '89 city e but, does it have a heat guard on the exhaust manifold?
Could it be loose and rattling?
#20 mrmeds
mrmeds
  • 239 posts
Posted 18 August 2024 - 09:02 PM
has upgraded lcb and exhaust - definitely no heat shield  now, even if originally did
#21 Pee
Pee
  • 51 posts
Posted 18 August 2024 - 09:28 PM
From experience knocks relating to power on/off were tracked down to a slight crack in the floor around the subframe mount visible from passenger side footwell. Second was the engine mount bracket had split. Probably due to already mentioned rubbish poly mounts we all installed back in the 2000’s. Pah!!
Both were hard to track and didn’t show when rocking the engine by hand.
