Pitting On Cam Followers - Possible Causes ?
19 replies to this topic
#16 PoolGuy
PoolGuy
  • 836 posts
Posted 24 July 2024 - 01:31 PM
I wonder what AC thinks? He’s championed those followers in the past.
#17 KTS
KTS
  • 2,392 posts
Posted 24 July 2024 - 02:45 PM
for what it's worth, i have to agree with Keith's observation that the camshaft itself is demonstrably of such poor quality (i.e. unfinished journals) that in this particular case it's far more likely (..because without laboratory analysis it is all just speculation and probabilities...) that the damage has resulted from the camshaft that's been used rather than an issue with the followers.
#18 super6al
super6al
  • 79 posts
Posted 25 July 2024 - 12:26 PM
hi sorry to hi jack this post, but is there anyway to check the followers will rotate correctly before the engine is fully built. I have my engine partially built ( head not fitted) and I just installed new followers without realising any checks were required.
thanks
#19 PoolGuy
PoolGuy
  • 836 posts
Posted 25 July 2024 - 01:06 PM
Yes, they should turn when the engine is turned over by hand. Not much, maybe only 1/4 turn per couple of revolutions of the crank.
#20 sonscar
sonscar
  • 2,938 posts
Posted 25 July 2024 - 01:56 PM
I understood that the curve of the followers in conjunction with taper on the cam lobes caused the rotation.Might be a case for inspecting the camshaft as well.Steve..
