Can anyone help?
I am looking for a 1071 MK1 cooper S crankshaft main bearing cap set, (3 off).
Regards,
246jaenick
Posted 02 April 2024 - 06:13 PM
Can anyone help?
Regards,
246jaenick
Posted 02 April 2024 - 06:57 PM
They are matched to the block.
you may as well buy a set of caps from MED or KAD as you will need to have the block and caps line bored.
Posted 03 April 2024 - 09:22 AM
yep...
unles your going for a concourse build, its probably easier/ just as cost effective to get a set of uprated steel mains caps
Posted 03 April 2024 - 11:55 AM
Posted 03 April 2024 - 01:18 PM
Oh dear, that is going to be expensive.
I used to line bore mains, but even with the special tool that I made, it was time consuming.
If you had the front and rear main caps, it is straightforward to line bore the centre main, and when that has been done, it simplifies locating the tool that cuts the "face" for the thrust washers.
Without any caps, it takes a lot of time lining up and realigning
Posted 03 April 2024 - 05:33 PM
Posted 03 April 2024 - 05:53 PM
From memory, the S main journals are a different width from the mainstream 1275 ones. I might be wrong, but best to check it.
They are indeed and the early 1071 caps were different again.
Mini Technical Sections →
Problems, Questions and Technical →
Can You Help Me Guys With My Hs4Started by Notwabel , 26 Dec 2024 engine |
Clutch Not DisengagingStarted by Sharks , 15 Dec 2024 engine |
Possible Transmission Problem?Started by aguiloco , 07 Dec 2024 engine |
Crud In Combustion Chamber.Started by Rubbershorts , 16 Nov 2024 engine |
Full Rebuild MethodologyStarted by PeteD , 16 Nov 2024 engine, electrical |
