Mini Spi Charging Issue
electrical
2 replies to this topic
#1 Dutch_MiniSPI
Dutch_MiniSPI
    Starting My Mini Up
  • 1 posts
Posted 27 March 2024 - 02:13 PM
Hi everyone I'm the proud owner of a Mini SPI Balmoral edition. Like a lot of other owners I have a charging issue but can't find the solution.
I changed the alternator and battery for new ones and cleaned all the ground surfaces and added an extra one. Everything is working fine but what I see is my charging warning light is on when it is not started, but after I start the car it still illuminate slightly. I changed all the fuse links with straight wires, and replaced the connector which connects to the alternator. I also checked the brown/purple lines between the alternator and the starter and they are fine.
#2 lsto
lsto
  • 585 posts
Posted 28 March 2024 - 03:57 PM
Have you checked what voltage is coming out of the alternator and then what your getting at the battery? Could be a duff alternator, if you have changed the obvious then you need to measure and can diagnose from there.
#3 viz139
viz139
  • 656 posts
  • Local Club: Irish Mini Owners Club
Posted 29 March 2024 - 10:25 AM
First thing I would do is confirm the correct operation of alternator. Put a voltage meter on battery and get 12v than start engine and should get 14v.  Its unlikely you have two alternators with the same fault so more likely a bad connection in the charge light circuit. First place I would check is the PCB on the back of the clocks .
