Hi all,
My 95 Spi has recently started to misfire on starting before cutting out after a few seconds. After this it won't start for a couple of hours just turn over with out firing.
So far I've changed the spark-plugs, ignition coil & ignition leads but to no avail!
I've also checked all the vacuum hoses running from ECU to the fuel trap and beyond, but all seem to be intact. I'm also pretty confident that the fuel pump is working as I can hear it prime and run before it cuts out.
Any help or suggestions on what I need to check next would be greatly appreciated. (Or if someone could recommend a mini mechanic in Northern Ireland that would be great too!!!!!!)
Vinny
