Emissions And Historic Vehicles
6 replies to this topic
#1 Davetom
Davetom
  • 39 posts
Posted 01 March 2024 - 07:21 AM
Hi all, first post.. if I have an historic registered Mini but put a newer engine in, would I then have to Mot it and subject it to emissions testing ? Tha
#2 Quinlan minor
Quinlan minor
  • 1,170 posts
  • Local Club: LSMOC
Posted 01 March 2024 - 09:11 AM
No simple answer:
https://www.gov.uk/historic-vehicles
https://www.gov.uk/g...mption-criteria
Engine
Alternative cubic capacities of the same basic engine and alternative original equipment engines are not considered to be a substantial change.
If the number of cylinders in an engine is different from the original it’s likely to be, but not necessarily, the case that the current engine is not alternative original equipment.....
Acceptable changes
It does not count as a ‘substantial change’ if:
  • changes are made to preserve a vehicle because the original type parts are no longer reasonably available
  • they are changes of a type which can be demonstrated to have been made when vehicles of the type were in production or within 10 years of the end of production
  • axles and running gear have been changed to improve efficiency, safety or environmental performance"
#3 Davidmt
Davidmt
  • 203 posts
Posted 01 March 2024 - 09:45 AM
I have a 1980 1275GT with a later 1400 Minisport engine in it.  I decided it was just an alternative cc of the same basic engine (which it is!) and therefore claimed the exemption without issue.  I don't think putting a newer version of the same basic engine is too contentious!?
#4 Davetom
Davetom
  • 39 posts
Posted 01 March 2024 - 10:29 AM
It would be a 1380 so I’d probably just assume it would be a legit replacement
#5 mab01uk
mab01uk
  • 12,413 posts
Posted 01 March 2024 - 01:18 PM
This thread linked below may also help.
Tax Exempt Cars, Engine Change - Dvla?
https://www.theminif...ne-change-dvla/
Edited by mab01uk, 01 March 2024 - 01:19 PM.
#6 weef
weef
  • 489 posts
Posted 01 March 2024 - 01:33 PM
As it is classified Historic there is of course no need for an MOT test, but if you submit the vehicle for an MOT test your possition as regards emmission testing is covered by section 8.2.1.2 of the MOT guidelines.
Section 8.2.1.2 says that vehicles used before 1st September 2002 fitted with a different engine must be tested to the requirements of whichever is older.
As an example a 1995 vehicle fitted with a 1991 engine (of whatever make), must be tested to 1991 standards for emmission purposes.
The onus is on the vehicle presenter to prove engine age
#7 Davetom
Davetom
  • 39 posts
Posted 01 March 2024 - 03:18 PM
Thanks all, really helpful
