Watching this video from AC Dodd https://youtu.be/Vnv...26Id1Xde4hSWqdo it would seem i should have a coil measuring 0.8 ohms. I have a 65d distributor with electronic ignition from a 1988 Metro
The coil currently fitted measures 1.5 ohms and apparently should have a ballast resistor. I don't know if it has. Are they inside the coil or located separately? I don't know if i should fit the 0.8 ohm coil. I don't want to connect it up and cause damage by having a ballast resistor with a coil which shouldn't have one
I don't know if this is any help but this is the wiring at the coil
IMG_20230407_114325_528.jpg 92K
3 downloads
