Rwd 4X4 V8 Mini
9 replies to this topic
#1 joakwin
joakwin
  • 958 posts
Posted 25 February 2024 - 08:33 PM
ive had this mini shell since 2009, it was a rhd mayfair automatic, it had alot of rust,
the car was black when i got it, and then when i rebuilt the shell, i painted it a cream color.
and then when i did the wide body, i painted it od green
im going to repaint the car when im done rebuilding it, but i dont know what color yet
over the years, its had a 998/auto, and then a metro 1275/auto,
and then it had a built d16z6-itb/manual, and then a stock d16z6/auto
now its getting a lm7 truck ls base motor, 5.3 v8, and a automatic trans, and a right side drop np241c with vss
#2 joakwin
joakwin
  • 958 posts
Posted 25 February 2024 - 08:44 PM
this is the motor, i rebuilt it last summer, stock bore 5.3 liter v8, should be good for around 300hp, and around 330tq, i left the stock size cam in the engine,
i just want it to run like stock, should be okay for a lifted mini on 35's
#3 joakwin
joakwin
  • 958 posts
Posted 25 February 2024 - 08:45 PM
#4 joakwin
joakwin
  • 958 posts
Posted 25 February 2024 - 08:47 PM
only upgrade i did was stock ls6 valve springs, and new valve seals and sealed the valves to the head
new gm 5.3 head gaskets, and new head bolts
#5 joakwin
joakwin
  • 958 posts
Posted 25 February 2024 - 08:49 PM
body bolted down to the frame, with some stock cj7 poly body bushings
the rolling chassis is a jeep cj7, thats been shorten down to 2 inch above a cj5, so the axles will be moved outward 2-3 inches, cant remember off the top of my head
Edited by joakwin, 25 February 2024 - 09:10 PM.
#6 joakwin
joakwin
  • 958 posts
Posted 25 February 2024 - 08:52 PM
another engine pic
mock up drivetrain being fitted to the frame
mock up engine and transmission case before i put a oil pan on it
#7 joakwin
joakwin
  • 958 posts
Posted 25 February 2024 - 08:55 PM
np241c right side drop with vss, unicorns of transfer cases, only made for like 2-3 years
rebuilt, new chain, bearings and seals
with short output shaft kit
#8 joakwin
joakwin
  • 958 posts
Posted 25 February 2024 - 08:57 PM
 garage speakers
Edited by joakwin, 25 February 2024 - 08:57 PM.
#9 joakwin
joakwin
  • 958 posts
Posted 25 February 2024 - 09:03 PM
i have to wait to after the winter to start on building the sheet metal tunnel for the 4x4 mini, i cant bring the 4x4 inside my garage because i have my g10 3 cylinder, 75 lhd mini shell inside right now, i rebuilt the shell this last winter
building a jig for the rear suspension arms, im going to start next weekend, im going to build a beam as well out of 1-3/4 tube
rear disc brake hub i built for the g10 mini
#10 joakwin
joakwin
  • 958 posts
Posted 25 February 2024 - 09:08 PM
thinking about painting the roof a gloss black color, still need to clear the shell, and paint was still kind of wet in this pic
Edited by joakwin, 25 February 2024 - 09:17 PM.
