1Mm Decompression Plate
9 replies to this topic
#1 robert.hedges
robert.hedges
  • 53 posts
Posted 24 February 2024 - 08:25 PM
Struggling to fine one. Does anyone have an idea where I can purchase one for a 998? I have thought about a overthick (shimmed) cosmetics gasket but they only appear to come in 1275....
I want a decompression player so that I can bring it back to current CR if things don't work out. Please don't tell me to increase chamber size, piston dish etc.
Edited by robert.hedges, 24 February 2024 - 08:26 PM.
#2 Shooter63
Shooter63
  • 996 posts
Posted 24 February 2024 - 10:26 PM
Cometic do small bore gaskets from 32thou to 80 thou thick, one should be OK for you.
Shooter
#3 r.tec
r.tec
  • 180 posts
  • Local Club: SfG Schoenau
Posted 25 February 2024 - 09:56 AM
I have a Cometic copper gasket on a high compression 998 engine. Copper means here full copper, nothing else. My verdict: completely useless.
I had 998 shape stainless steel compression plates manufactured (I have to measure but I think they are 1mm). And I have left some of them.
But notice that you have to fit two gaskets below and on top of the plate.
If you cannot find a plate in Brittain we could perhaps arrange that I send you one although I do not know how to send something from a private person to a private person. That was simply forgotten in the Brexit agreement. What a shame!
Helmut
#4 timmy850
timmy850
  • 3,235 posts
  • Local Club: MITG
Posted 26 February 2024 - 10:07 AM
I guess you have seen Vmax make a 2mm decompression plate?
Another option is to use two head gaskets and no decompression plate
Or with some slight mods you can use a 1275 gasket
#5 lsto
lsto
  • 583 posts
Posted 29 February 2024 - 03:59 PM
What cc does a 1mm decomp plate work out as? I have a 998 turbo that I use as a daily. A copper HG works out about 3cc and I used 2 copper gaskets to drop my CR. Running a slightly home polished cam4810 head and standard pistons at 7psi.
Car is used as a commuter daily with no HG issues.
Edited by lsto, 29 February 2024 - 04:00 PM.
#6 r.tec
r.tec
  • 180 posts
Posted 29 February 2024 - 06:30 PM
According to my calculations (or better that of FreeCAD FCInfo Macro) the volume for a 1mm plate and 998 gasket is 3.7 cm³ per cylinder.
#7 DeadSquare
DeadSquare
  • 3,066 posts
Posted 29 February 2024 - 10:42 PM
To cut four 64.5mm holes in a plate with a milling machine, would cost about £100-00.
Using a head as a jig for the cylinder studs, I used to drill through a decompression plate, into a piece of wood.
Using a 2" QMax cutter, I'd mark out the bores.
By juggling bolts to hold the plate in place, it is possible cut the plate as the block it being rebored.
#8 mini13
mini13
  • 3,810 posts
Posted 01 March 2024 - 08:18 AM
Well... I dont like decomp plates so my advise is.... change the chamber volumes....  as decomp plates screw up the squish band
I would help if we know the background behind this, I assume some kind of forced induction?
However, I have just stacked 2 head gaskets before as a temporary measure to get CR down to run a turbo.
#9 robert.hedges
robert.hedges
  • 53 posts
Posted 13 April 2024 - 07:25 AM
For anyone interested I managed to source a very thick copper gasket from Cometic. It was about 0.094" which is the thickets they do in copper. It's not a stock item and has taken 8 weeks to arrive. It cost around £90 + VAT and delivery but to my mind its better then a 1mm decompression plate and two gaskets. Really happy with this approach. Now to progress with the supercharging.
Edited by robert.hedges, 13 April 2024 - 07:26 AM.
#10 DeadSquare
DeadSquare
  • 3,066 posts
Posted 13 April 2024 - 01:41 PM
Well done, finding that.  Thank you for telling us, that is useful for other supercharging ventures.
I think that was a fair price.
