Coil Spring Kit
15 replies to this topic
#1 propjock
propjock
  • 49 posts
Posted 22 February 2024 - 01:05 PM
I live in vegas where it is hot and dry. My mini has the original rubber springs and they need to be replaced. I was thinking of replacing them with this kit. Any thoughts?
#2 RooBoonix
RooBoonix
  • 1,224 posts
Posted 22 February 2024 - 01:08 PM
Plenty of past posts on the forum about coil springs. Most kits are poorly designed and severe damage to subframes is the result of the springs going coil bound on full compression.
Generally not recommended unless specific modifications have been made and the car is being used exclusively on a perfectly smooth surface, like a race track.
The rubber cones are superior in almost every way for a road going car.
#3 Quinlan minor
Quinlan minor
  • 1,170 posts
  • Local Club: LSMOC
Posted 22 February 2024 - 01:16 PM
Coil springs are ideal, for closing the valves, but absolutely not for the suspension on a Mini.
#4 Gaz66
Gaz66
  • 894 posts
Posted 22 February 2024 - 01:18 PM
Read people's comments on these in past threads.
That should see you buying new cones 👍
#5 Ethel
  • 25,919 posts
Posted 22 February 2024 - 01:32 PM
Minis have complex suspension requirements. Limited wheel travel, low weight with, potentially, a big range of gross loaded weight. That's why the engineers chose rubber. It would be hard to achieve the same with steel springs & nigh on impossible in a setup designed to be optimal for rubber cones.
#6 nicklouse
  • 18,577 posts
Posted 22 February 2024 - 01:56 PM
Don’t do it.
#7 gazza82
gazza82
  • 3,012 posts
  • Local Club: TMF+
Posted 22 February 2024 - 05:39 PM
Something to put you off ...
https://www.theminif...=+coil +springs
#8 I hate Brian
I hate Brian
  • 782 posts
Posted 22 February 2024 - 05:55 PM
Here we go again  :D
#9 StefanMini
StefanMini
  • 85 posts
  • Local Club: M.S.C.N
Posted 23 February 2024 - 12:54 AM
Had some coil springs, but after a year I replaced them by new rubber cones. Now my ride is much better. Also if a coil spring snaps on the motorway you don't want to know what happends..
#10 Mini Manannán
Mini Manannán
  • 2,856 posts
  • Local Club: man Estate
Posted 23 February 2024 - 07:45 AM
↑This.
I bought my car with coils, it was crap. Changed to cones and it's much improved.
#11 andyapanel
andyapanel
  • 623 posts
Posted 23 February 2024 - 12:35 PM
Use the Evo donuts from Minispares; I fitted them to my RSP last summer.
#12 madazv8
madazv8
  • 119 posts
Posted 23 February 2024 - 12:57 PM
As everybody else has said.  NO.  My mini had them fitted when I bought it.  The handling was frightening on twisty roads,  turn in was weird.  I replaced with new rubber cones, and I was amazed at how soft the ride was and the handling returned to what a Mini should be like.   On removal, one of the rear Hi-Lo adjusters was found to be bent due to the bottoming out described above.
#13 nicklouse
  • 18,577 posts
Posted 23 February 2024 - 06:07 PM
Just because we fit them to race cars does not mean they are any good. It just means we can play with them. And the fastest Minis track Minis Don’t use them.
#14 Tornado99
Tornado99
  • 750 posts
Posted 27 February 2024 - 10:25 PM
Recently came across "struts" for the Mini....springs over the actual shocks....nothing in the cones location. That seems like a very poor idea as all loading now must go through the body panel that used to just take the shock absorber/dampener loading.
#15 nicklouse
  • 18,577 posts
Posted 27 February 2024 - 10:42 PM
Commonly know as Coil overs. Again without body mods they mount in totally the wrong location not to mention the forces.
