Dear forumites - grateful for your help. I have a 1962 woody that has been converted to negative earth. The fuel gauge stopped working, which I traced to a faulty sender unit. I replaced the sender unit (from minispares) and the gauge worked again, but in the opposite sense: it shows empty when full and vice versa. This hasn't been a problem but I now want to change the gauge (it is a silver gauge in a black speedo) and want to make sure I get the right one. Am I correct in thinking I need to obtain a standard gauge (such as this one https://www.minispar...|Back to search) and only reverse the wires on the gauge to make it work the correct way? Or is there something else I need to do to make it work properly? A secondary question: can I simply fit a voltage regulator (for example https://www.minispar...ck to catalogue) to dampen the gauge's movement?
Very grateful for any advice
Best wishes
Mike
