Timing Light Not Working - No Signal
electrical
5 replies to this topic
#1 adman020
adman020
  • 21 posts
Posted 13 February 2024 - 09:28 AM
Trying to set timing but I can't get a signal to the timing light. The car idles at 900rpm with a live constant feed off the fuse box and ground off head bolt. I have tried turning the pickup 180 degrees, moving it closer to the dizzy and on other leads.
Timing light was working a month ago so thought this is odd. I have tried another timing light and this one has a light which lights saying check connection? I do have a spark from ht lead to cylinder 1.
Could it be that the spark/signal is too weak to pickup? or is there something else i can try before buying yet another timing light.......
(1980 mini HL 998)
#2 68+86auto
68+86auto
  • 1,494 posts
Posted 13 February 2024 - 10:41 AM
Connect the positive for the timing light to the lead coming from the battery.
What was it that the other timing light did?
It is obvious but I need to check that you are in fact pulling the trigger?
Edited by 68+86auto, 13 February 2024 - 10:41 AM.
#3 adman020
adman020
  • 21 posts
Posted 13 February 2024 - 12:44 PM
Yes i have tried that pressing the trigger on both and holding down etc. Also tried connecting both timing lights directly to a fully charged spare battery. Before i had no issues.
#4 slidehammer
slidehammer
  • 1,213 posts
  • Local Club: LSMOC
Posted 13 February 2024 - 02:34 PM
I would try the timing light on another vehicle and if you get the same result and all the connections are good then the light must be dead.
#5 smurfomatic
smurfomatic
  • 477 posts
Posted 13 February 2024 - 02:44 PM
Try the timing light on a different plug lead, just to see if it'll pick up on that instead.
#6 68+86auto
68+86auto
  • 1,494 posts
Posted 13 February 2024 - 11:59 PM
Then I would do as the others have said (I left it out of my original comment to keep it simple). The other vehicle/engine can even be a mower etc.
