Evening All,
I have a 1986 998 A+ Mini Mayfair.
My first Mini and I've had it just over a year now, first winter it was fine but came off the road over the summer to have some MOT welding done, since then it has never quite run right, like it's misfiring but on all four cylinders.
So far it has had the following checked/adjusted/replaced, fuel mixture, timing, valve clearances, carb flange resealed (air leak), new fuel pump (fuel leak), plugs (correctly gapped), rotor arm, cap and HT leads. It has also had a compression test all four cylinders were 150-160.
Now the previous owner fitted an Accuspark conversion kit with a standard coil and at first I thought it had the wrong coil as the car should have had a ballast ignition system, this led me to believe that the coil was possibly producing a weak spark. I have since learned from him that he removed the ballast wire at the same time. However having read KernowCooper's previous post about converting to standard coils I think that the 12V feed has been done wrong as there is no clear wire from fuse 1 to the coil +.
There is however a red wire which comes from the + on the coil and joins up with the original white/yellow wire to the starter solenoid and a "mystery" brown wire out of the same section of loom (I will add a photo as soon as I figure out how).
My next step is to test the voltage going to the coil but in the meantime my questions are:
Would this arrangement likely result in insufficient voltage to the coil (especially when ancillaries running)?
What is the brown wire connected to the white/yellow wire?
Would disconnecting the red wire from the coil + and connecting a proper feed (as per KernowCooper's instructions) have a detrimental effect on something else?
All other electrical elements seem to run fine and the battery always holds a good charge, I have tested the coil before and it seems to be okay but I could be wrong.
Thanks in advance.
