1275 Mechanical Fuel Pump Issue
7 replies to this topic
#1 Joepotato99
Joepotato99
    Just On Tickover
  • 7 posts
Posted 05 February 2024 - 10:56 AM
Hi,
Appreciate some advice on the following please. On a newly acquired 1972 1275 GT.
Broke down yesterday and suspected fuel issue. Had inlet hose to carb off, cranking engine and no fuel coming out at all. It has what looks like quite an old mechanical fuel pump on the engine.
Today I've taken the pump off, and as I did the pin holding the arm into the pump housing fell out. Also the plastic spacer between pump and engine were cracked.
Has anyone had this happen before?
Am I right in thinking this pin should be retained? And the arm would not work like this when bolted to the engine?
I have a new pump, spacer and gaskets on the way.Attached File  Screenshot_20240205_105744_Gallery.jpg   89.49K   7 downloads
Edited by Joepotato99, 05 February 2024 - 10:59 AM.
#2 slidehammer
slidehammer
  • 1,162 posts
  • Local Club: LSMOC
Posted 05 February 2024 - 01:49 PM
The pin should be retaining in the pump along with the arm that pivots on it. The edges of the pump housing peened over to prevent it from falling out into the engine.
Lucky you got all the bits out!
#3 Joepotato99
Joepotato99
    Just On Tickover
  • 7 posts
Posted 05 February 2024 - 03:30 PM
Thanks I see what you mean, surprising really as it's a tiny bit of peening that's visible.
#4 bpirie1000
bpirie1000
  • Area Managers
  • 2,282 posts
  • Local Club: Amoc
Posted 05 February 2024 - 04:17 PM
I would still consider looking for any loose bits on the next oil change..
Lucky boy though.. go get a lottery ticket...
If you win.... remember your minimforum friends....
#5 Midas Mk1
Midas Mk1
  • 5,752 posts
  • Local Club: S.U.N.M.C
Posted 05 February 2024 - 08:04 PM
Highly recommend the genuine su burlen mechanical pumps compared to the cheap ones on ebay, been there, swapped that a few a few weeks
#6 Lplus
Lplus
  • 822 posts
Posted 06 February 2024 - 10:58 AM
The witness mark on the upper of the two gaskets suggests the pin had come loose and moved towards the engine and was only retained by the gasket, hence perhaps the failure to  pump.  The plastic spacer has been opened out so far by a previous owner that it would no longer support the pin at each end.
Edited by Lplus, 06 February 2024 - 10:58 AM.
#7 coopertaz
coopertaz
  • 741 posts
  • Local Club: a-series-magpies
Posted 07 February 2024 - 11:26 AM
why had previous owner opened up spacer? looks like a gerbil has been in there
#8 Lplus
Lplus
  • 822 posts
Posted 07 February 2024 - 04:53 PM
Maybe they thought it should match the outline of the hole in the block?
