Electronic Ignition Distributor Cap
21 replies to this topic
#16 Kev Shepherd
Kev Shepherd
  • 21 posts
Posted 24 January 2024 - 06:20 PM
I've put 4 new plugs in now, so will see how that goes when I next go out. If it is anything like my other car, a '72 Karmann Ghia, it'll be temperamental!
#17 Designer
Designer
  • 582 posts
  • Local Club: LSMOC
Posted 25 January 2024 - 08:15 AM
That's why we love Minis so much it is all part of the fun of owning one. Built in from the factory :D
#18 Ethel
  • 25,922 posts
Posted 25 January 2024 - 10:22 AM
The fluffy part throttle is suggestive of a manifold or throttle shaft air leak - wary of chucking enough suggestions at you for a nut & bolt rebuild!
#19 Kev Shepherd
Kev Shepherd
  • 21 posts
Posted 25 January 2024 - 11:28 AM
Nut & bolt rebuild is definitely above my pay grade! I'll keep my fingers crossed for the temperamental option! It has a stage 1 kit with K&N filter, the previous owner had refitted the original airbox and made several holes in it as he felt it lagged a bit.
Since fitting the K&N I had the carb set up at a local classic car garage and it did run OK. I take it that it'll be ok just to leave as is and take into account the first little throttle input is a bit iffy, just for a second or two. After all, driving a Mini sedately is no fun, as the right foot can be a tad heavy.
#20 Kev Shepherd
Kev Shepherd
  • 21 posts
Posted 26 January 2024 - 05:38 PM
I've just done about 80miles in it at around 50mph, a couple of times 65! Got to say it went well and sounded good. The only real issue is that it has a tendency to stall when idling, sometimes it doesn't. One thing I have noticed is that after fitting a new water pump the temp gauge is now halfway between C and N. It used to be spot on N. Would this be because the new pump is performing better tha the old one?
Cheers,
Kev
#21 Midas Mk1
Midas Mk1
  • 5,777 posts
  • Local Club: S.U.N.M.C
Posted 26 January 2024 - 09:10 PM
Cheers,
Kev
Don’t forget what time of year it is, my daily cooper has a works grille muff on covering 90% of the airflow to get normal running temp and good oil temps on a motorway run .
#22 Kev Shepherd
Kev Shepherd
  • 21 posts
Posted 27 January 2024 - 02:36 PM
Ah....Good point . When I've sat in traffic is goes up to Normal. Lesson learnt. Muppet.
