Electronic Ignition Distributor Cap
Posted 22 January 2024 - 06:36 PM
I have a quick question about electronic ignition. I have a 1980 998cc fitted with electronic ignition and it has developed a misfire on No3. I have tried new plugs, swapped HT leads and it still has the misfire. I did clean the distributor cap terminals as they did have a bit crud on them, especially No3. I cleaned them up and refitted it....thought I'd cured the fault, no such luck.
No3 plug was sooted up, the others were pretty good. Do you think the cap could be an issue, possibly cracked? If so, can I fit a normal cap? It is a electronic ignition, but I do not know what brand as I can't see anything printed on it.
I have also done a compression test, all four were the same and also checked the valve clearances.
Thank you in advance for any help you could offer.
Cheers,
Kev
Posted 22 January 2024 - 07:00 PM
I do not think that there are any differences with the distributor caps. The electronic distributor only acts as a switch to trigger the ignition coil and does in no way enhance the spark intensity.
It may be worthwhile replacing the rotor arm at the same time.
Posted 22 January 2024 - 07:09 PM
Posted 22 January 2024 - 07:32 PM
Thank you for your replies, I will replace the cap and rotor arm and the misfire is occasional. Under load the engine pinks. It'll go along at 55mph and be fine. At slow speeds the car is sluggish initially then picks up. I will check for play when I am next in the garage.
Cheers,
Kev
Posted 22 January 2024 - 08:15 PM
Caps are not special. You just need the correct one to fit the dizzy body. There can be options on lead orientation but that’s it.
Posted 23 January 2024 - 08:28 AM
Yes just get a standard cap and rotor arm, either nos or from Distributor Doctor, avoid new Chinese rubbish!
Posted 23 January 2024 - 12:04 PM
Posted 23 January 2024 - 02:22 PM
There was an electronic specific cap, coloured blue. Doubtful the difference was much more than the colour, certainly not enough to make a standard cap not work.
We're all assuming it's not the factory fitted 65DM4 electronic dizzy off later models, that has screws in place of the spring retaining clips.
If you can't get rid of it, the rotor arm is in control of the firing order, so you could turn the dizzy body by 90 degrees & reposition the plug the same in the opposite direction on the cap so they match up with the rotor arm again. Of course you'll have to reset the timing, but you'll be able to say with more certainty if the fault is in the dizzy.
It's an A Series, so it could as easily just be varying degrees of "bangability" in that cylinder. A compression test may be worthwhile and reducing the gap for that plug may make just enough difference.
Posted 23 January 2024 - 03:15 PM
I have done a compression test, but numpty here didn't write down the results! They were all pretty close, one was a fraction lower....not sure which one. Will do another test soon.
Rotor arm and cap on order from Distributor Doctor, hopefully be here in a few days.
Cheers,
Kev
Posted 23 January 2024 - 10:53 PM
Compression tests are very subjective, as much a measure of the battery & starter motor. If the results were similar that's good enough.
The rotor moves against the springs of centrifugal advance, so it should rotate but spring back to its rest position.
Posted 24 January 2024 - 04:08 PM
So, it idles OK and when I remove the HT leads, No3 doesn't appear to affect the running, which is odd because I was doing 55mph no problem, no lumpiness in the engine. When I hold the HT lead just on the plug you can hear the spark. Is it a case of if it ain't broke...?!
The thing I notice now is that idle and at speed with the foot down it pretty good, it is the first quarter of throttle that appears a bit 'fluffy', almost hesitant, the engine labours for a couple of seconds and then off we go.
Sorry to keep this thread going, really appreciate your help.
Cheers,
Kev
Posted 24 January 2024 - 04:31 PM
Posted 24 January 2024 - 05:25 PM
Posted 24 January 2024 - 05:41 PM
Maybe take it round local garage and get them to down emmission test.
Ideally the rolling Road is the best place...dsashpot oil all correctly filled?
Posted 24 January 2024 - 06:15 PM
I'd say the exhaust note was in between if that is at all possible! Not too bad, definitely not like it is running on three cylinders and no scary smoke. Funnily enough I did top up the dash pot, that would have an effect on it then? It has been a few years since I had a Mini.
Cheers,
Kev
