Mini Engine Identification
engine
5 replies to this topic
#1 BigAidy
BigAidy
    Starting My Mini Up
  • 2 posts
Posted 11 January 2024 - 12:07 PM
Hi I am needing help with identifying two engines I have bought recently any infomation would be much appreciated! The below numbers were found on the block
1015/8632  (First Engine)
99h834aj/h5474  (Second Engine)
#2 MatthewsDad
MatthewsDad
  • 790 posts
Posted 11 January 2024 - 01:06 PM
Minimania has a detailed schedule and explanation of chassis and engine numbers.
#3 I hate Brian
I hate Brian
  • 782 posts
Posted 11 January 2024 - 01:12 PM
try guess works engine and gearbox decoder
#4 nicklouse
  • 18,366 posts
Posted 11 January 2024 - 05:02 PM
Pictures would be good.
first number is not as expected. Might be a local thing.
second is a 998.
#5 Spider
  • 14,613 posts
Posted 11 January 2024 - 05:03 PM
The first one (1015) is an Aussie built 1100 engine, they were fitted to the Mini (Clubman) range at the time, it would be a 1974 or 75 fitting, built to ADR27. Rod, 4 Synchro Gearbox, standard ratio, 3.44 final drive
The second (99H) is a fully imported Built Up Unit from the UK to meet ADR27A, fitted to Mini and Moke Range. These had a Rod Shift Gearbox, standard gear ratios. For the Mini, they had a 3.44 final drive and for the Moke, 4.2.
#6 BigAidy
BigAidy
    Starting My Mini Up
  • 2 posts
Posted 13 January 2024 - 11:35 AM
Thank you for the info spider!
