Thanks for the replies guys. Not had a chance to look at this as family is down with a bug again including me.
Is the regulator being easy to change also the case on MPI minis as it seems is quite different to previous ones from a quick look?
When i test the voltage at the alternator it kind of flickers around, have seen 14ish a cpuple of times but mostly its less than 1v.
The light goes totally off as you'd expect when all working fine and the volt gauge reads around 13V when lights etc off and drops to mid 12s when lights and heate are on
As a lot of the replies above I'd check the connections at the alternator, starter and battery, including earths are in good condition and not corroded. Ideally you want about 14 to high 13v at the battery with the engine running. If your getting this then turn on all your loads, and check again at the battery, you still want 13+ volts. If your only getting mid 12s when your loads are on and all your connections are good I would suggest your alternator is on its way out. In the cold battery's take a hammering and a weak charge will slowly kill the battery.
Good luck.
