Apologies if this is a stupid question and / or it has been asked before. My 1990 carb mini cooper has a K&N cone air filter, which is filthy. How do you take the filter apart to remove the cotton part of the filter for cleaning? There is very little room between the top of the air filter and the bulkhead, and I'm a complete novice, so I thought I would ask for advice before making a mess... Thanks in advance for your help.
Posted 31 December 2023 - 06:01 PM
Posted 31 December 2023 - 07:58 PM
Edited by Midas Mk1, 31 December 2023 - 07:59 PM.
Posted 31 December 2023 - 08:56 PM
Thank you very much. I'd better start by getting the tools you mention! Where is the retaining bolt on the filter? Does the top of the filter simply unscrew and then you can lift the fabric filter material out of the top?
Posted 31 December 2023 - 11:19 PM
No need to remove the intake system with a paper filter housing.
Posted 01 January 2024 - 08:18 AM
Posted 01 January 2024 - 11:22 AM
Thanks everyone! That picture was really helpful - I managed to simply undo the nut on top and wiggle out the filter.
Posted 01 January 2024 - 12:42 PM
Be careful when cleaning it.
Roll it about in a shallow tray to free the dirt on the outside, rinse it from the inside. Don't dunk it, so what's on the outside can get in to the inside.
It's best to take a couple of days: wash - let it dry for a day, oil - let it disperse for a day.
Posted 03 January 2024 - 10:58 AM
ahh the ease of a reusable filter. lol
Mini Technical Sections →
Problems, Questions and Technical →
Clutch Not DisengagingStarted by Sharks , 15 Dec 2024 engine |
Possible Transmission Problem?Started by aguiloco , 07 Dec 2024 engine |
Crud In Combustion Chamber.Started by Rubbershorts , 16 Nov 2024 engine |
Full Rebuild MethodologyStarted by PeteD , 16 Nov 2024 engine, electrical |
Low Compression Across The BoardStarted by Vinay-RS , 11 Nov 2024 engine |
