Magic Wand In Detail
11 replies to this topic
#1 gaspen
gaspen
  • 942 posts
Posted 21 December 2023 - 03:18 PM
Hello
I need some light ! Could somebody show me a m/w gearbox lever in its place and/or a picture of the lever seat in good condition?
I must restore it somehow because I don't find replacement.
1st picture:  there is a small "detent" on the lever's seat. Its width is about the half of the groove. It worn out it is allright ? Maybe this one limts the side movement of the lever ?
2nd picture : the pin which drives the gear lever is position fallen out from the seat. How was it fixed into the seat ?
 Attached File  20231221_120058.jpg   24.65K   3 downloadsAttached File  20231221_120145.jpg   28.76K   4 downloads
#2 mab01uk
mab01uk
  • 12,413 posts
Posted 21 December 2023 - 05:02 PM
I assume you have the later type of magic wand gearlever assembly which came in with the 4-syncro gearbox/Mk2 Mini 850 and was introduced to use the remote gear change style of diff housing?
The 4 synch magic wand gearlever is also different to the 3 sync magic wand gearlever, ie. has the keyway slot in the ball at the top not the side.
The earlier magic wand 3-syncro gearbox (Mk1 Mini 850) also had a different 'tower' type diff housing.
The following parts in photo above (not mine) are for sale as a kit on the Mk1 Forum which may be of interest (you may need to register to view the ad)
Magic Wand Direct Shift Kit of parts:-
http://mk1-forum.net...=332739#p332739
Sell Magic Wand Direct Shift Kit of parts suitable to convert a Remote Diff Case into a Magic Wand Gearstick.
22A1382 Gearlever 1968-75 later type wand with Ball Slot at the Top ( Used)
2A3467 Bush ( used)
2A3390 Spring ( Used)
88G553 Smoking Pipe Shaft ( Used)
22A1717 Cover adaptor plate (Used)
22A1832 Seat/ locating Foot ( NOS) in Leyland box with part no 22A1822 normal oddity that Leyland box has a different part number to the part.
22A419 Gaiter ( BMC NOS ) supplied with the BMC box
@ £150. + post.( not supplied 4x bolts to secure the under Cover & the Dust Gaiter & its support wire that covers the gearstick into the diff case )
Edited by mab01uk, 21 December 2023 - 05:19 PM.
#3 mab01uk
mab01uk
  • 12,413 posts
Posted 21 December 2023 - 05:17 PM
This thread below on the Mk1 Forum also has some useful information on the later magic wand setup.
(As said you need to register first to view the Technical part of the forum).
Magic wand Remote Gearbox:-
http://mk1-forum.net...php?f=3&t=11555
#4 timmy850
timmy850
  • 3,330 posts
  • Local Club: MITG
Posted 21 December 2023 - 08:19 PM
How well does the “thick end” of the pin fit the groove on the gearstick?
It appears to me that the pin should be the same diameter the whole length and the pin is very worn
#5 gaspen
gaspen
  • 942 posts
Posted 22 December 2023 - 11:30 AM
For me it looks like that pin is produced to this shape. I believe that the tapered shape has its purpose but I don't have a clue  :D
Attached File  20231222_122307.jpg   51.77K   0 downloads
#6 Ethel
  • 25,922 posts
Posted 22 December 2023 - 12:40 PM
Zero experience of 'em, but it looks like the pin might go the other way round to allow some lateral movement. Expect its purpose is just to stop the stick turning turtle under its own weight.
The Australian market spec likely has the pin on the other side.
#7 gaspen
gaspen
  • 942 posts
Posted 22 December 2023 - 01:21 PM
A picture from the web shows that the pin rises just a little bit.
Anyway, I'll try put a threaded insert to the seat with a new pin.
Attached File  22A1832.jpg   41.1K   1 downloads
#8 gaspen
gaspen
  • 942 posts
Posted 22 December 2023 - 01:56 PM
I think I'm figured it out : maybe the tapered shape should hold a spring which holds the pint in the hol also ? Becuase the groove on the sphere is flat, and the pin must follow its shape.
#9 timmy850
timmy850
  • 3,330 posts
  • Local Club: MITG
Posted 22 December 2023 - 08:31 PM
The second photo in your first post - the alloy foot/seat looks to be quite worn too. My guess is the wear here, plus the pin means it’s just worn out. The gear stick would have been much stronger than the alloy
The photo of the new item doesn’t seem to have the same taper on the pin
#10 Ethel
  • 25,922 posts
Posted 22 December 2023 - 08:56 PM
The surface finish suggests it's as intended & the cone end is the business end by the wear marks. If you can visualize how the two faces of slot in ball would would move to describe a segments (in an orangey analogy), the cone on the pin could fit snugly between them.
#11 gaspen
gaspen
  • 942 posts
Posted 22 December 2023 - 09:58 PM
Yes. Because the tapered end is IN the hole, positioned inwards. The taper itself holds a spring.
The non-tapered end  positioned outwards and it sits in the groove of the gear lever's sphere
Attached File  Névtelen.png   4.54K   0 downloads
#12 gaspen
gaspen
  • 942 posts
Posted 23 December 2023 - 07:39 PM
Well there isn't any spring under the pin  :proud:
Today I repaired the piece with a threaded insert
Attached File  20231223_140432.jpg   43.19K   0 downloads
