Who's Using Who's Dog Kit?
17 replies to this topic
#16 PoolGuy
PoolGuy
  • 846 posts
Posted 21 January 2024 - 01:38 PM
Out of interest, what oil do you use with a dog box, I presume some sort of motorcycle rated stuff?
Shooter
In what environment?
#17 Spider
  • 14,818 posts
Posted 22 January 2024 - 04:21 PM
The swiftune and KAD ones with the extra laygear bearing look good, I wonder if the extra bearing makes a difference?
Support of the Laygear in these Mini Gearbox has always been marginal, though the 3 step Layshaft did improve matters, any additional bearings are going to help here.
Shooter
One up-side of going to a Dog Box is it opens the door to the use of synthetics.
#18 Shooter63
Shooter63
  • 1,024 posts
Posted 24 January 2024 - 06:25 PM
The reason I asked is that with a dog box there must be some extreme pressures going on when the dogs engage which must be exaggerated by the speed that the gears are rotating, obviously in a M/C there is a reduction of around 3:1 which means even if the engine is revving to 12K the box is only at 4K plus you have an extremely fast shift cycle, but then I suppose a dog box is a race item so life expectancy isn't that important.
Shooter
