Selector Fork Weld-Up
37 replies to this topic
#31 Ethel
  • 26,820 posts
Posted 19 December 2023 - 11:26 AM
They do look like they could've made in the bronze age & it could be a nice side-line for somebody with surplus melt from bigger castings.
#32 gaspen
gaspen
  • 1,194 posts
Posted 19 December 2023 - 11:45 AM
I've thought about this on and off many times. I'd make a fixture for sure, it would just make the job so much easier and repeatable. While they could be machined in a lathe, I'd most likely do them using the Fixture in the Rotary Table on the Mill. I'd say the factory most likely had a cutter that would have done both faces of the fork in a single operation, though, to maintain precision and finish, I'd only at one side at a time.
Sure, I'm just trying to brainstorm (fart) a least cost 'n most amateurish way to do it. Agree, the best solution  would be for some kindly expert machinist to gather up all the dead ones and do a batch of 'em  :P
If you were try a replaceable face approach, might it be easier to fab up some sort of carrier, a bit like a brake caliper & pad arrangement?
The forces involved can't be too bad, even with a foot & half of gearstick. I'm imagining a kind of sandwich of CNC cut plates & possibly a scrap gearbox to serve as a welding jig.
I know Mr Guess is planning to get them recast.
Mr. Calver overtook Mr. Guess
Gearbox (calverst.com)
#33 Spider
  • 15,878 posts
Posted 19 December 2023 - 06:16 PM
Doing them - no matter which road is take - as a batch is definitely the way forward to make them worthwhile if yr concerned with the scale of economics.
I had considered in the case of the replaceable faces that a standard fork may not have enough meat where it's needed. If a carried was made, it could be done in steel for sure.
Having them cast up is fairly inexpensive, but there are a few machining operations. I think at that point, while a fixture would still likely be needed, machining them by CNC would be the go.
#34 gaspen
gaspen
  • 1,194 posts
Posted 11 February 2024 - 06:46 AM
After some research I learnt that it really needs to know the exact materials of the forks. I know some company for this task but couldn't contact them - yet.
Without this info there is a risk of a bad welding/soldering and it could fell off.
But finally I purchased a pair of NOS forks which fit nicely to the rings. Both are spanish castings, hence there is  "NMQ-BMC" marking on them. They are a little bit different compared to the english forks. These forks have full contact surfaces.
Attached File  20240211_072742.jpg   51.86K   0 downloadsAttached File  20240211_073516.jpg   33.96K   1 downloads
#35 gaspen
gaspen
  • 1,194 posts
Posted 11 February 2024 - 05:39 PM
I want to tell you folks
What I learnt about the forks
I spent my day in the workshop with my new forks. I just put in the two new pieces then the assembled 3rd motion shaft.
This what I saw : the syncro hub won't sit in the fork. I thought that I made a mistake but did not find any.
Attached File  20240211_154028.jpg   55.41K   0 downloads
After many put-in/take-out I examined the forks. Look the picture on th e left : the 3/4 fork is not on the same axle as the 1/2. Also the selecting rods are in a weird position.
Fortunately I have one more good 3/4 fork which saved the situation. See the picture on the right
Attached File  20240211_160957.jpg   32.6K   1 downloads  Attached File  20240211_161947.jpg   33.26K   1 downloads
#36 imack
imack
  • 2,382 posts
Posted 11 February 2024 - 05:55 PM
I had exactly the same problem with a NOS 3rd/4th gear selector fork for a 22g1128 box. It appeared that the securing bolt hole had been drilled slightly out of position. Ended up refitting the Minispares reproduction item.
The NOS 1st/2nd fork was perfect.
#37 gaspen
gaspen
  • 1,194 posts
Posted 11 February 2024 - 07:29 PM
What is your opinion about the MiniSpares product ?
#38 imack
imack
  • 2,382 posts
Posted 12 February 2024 - 05:14 AM
I bought mine from minispares about 7 years ago, so things might be different now.
I had to return the first 3rd/4th selector as it was miss-machined. The 1st/2nd selector had excess clearance with the hub, but I ran with it until I got a NOS genuine one (which fitted perfectly)
The 3rd/4th minispares selector I currently have is very good.
