Alternator / Dynamo Options
5 replies to this topic
#1 MatthewsDad
MatthewsDad
  • 806 posts
Posted 27 November 2023 - 07:47 AM
1968 Cooper positive earth
Hi, I'm considering changing the original dynamo to one of the alternator types which look like a dynamo.
There are various options with a big price range. Dynamator around £180, Dynalite about £420, Powerlite Lucas made in UK around £570.
Any feedback on reliability/ performance/ value for money would be appreciated. The mini is standard in terms of electrical load.
#2 whistler
whistler
  • 1,788 posts
Posted 27 November 2023 - 09:21 AM
Unless you're running a full set of spotlights for hours or heavy ampage sound system then your dynamo is fine. Having just restored a 66SDL I retained the dynamo as there was no good reason to go to an alternator and chop up the wiring harness.
#3 JXC Mini GT
JXC Mini GT
  • 841 posts
Posted 27 November 2023 - 09:51 AM
My 1968 Cooper S positive earth had a dynamator already fitted when I purchased the car, it has worked fine in my ownership and looks the part, if you were to change I think converting it to negative earth at the same time is worthwhile as accessories (dash cam etc) are mainly negative earth.
Edited by JXC Mini GT, 27 November 2023 - 03:55 PM.
#4 floormanager
floormanager
  • 676 posts
  • Local Club: Mini Club Sussex
Posted 27 November 2023 - 06:38 PM
I still run a dynamo in my '68s.  The only change from standard I have in the charging circuit is an electronic regulator as I could not get one of those horrid replacement mechanical regulators to work.  I fitted the electronic one under the casing of the original voltage regulator and it's been perfect.  I worried about fitting an alternator as on original wiring, so potential to overload (not an auto electrician so not an expert).
https://www.dynamoregulator.com/
#5 Steam
Steam
  • 744 posts
  • Local Club: Victorian Mini Club
Posted 28 November 2023 - 01:06 AM
Dynamos work well but as has been noted above the main letdown is the control box. An electronic regulator will make the dynamoo a great charging choice.
#6 MatthewsDad
MatthewsDad
  • 806 posts
Posted 28 November 2023 - 09:47 PM
Thanks everyone for your advice. Think I'll keep the dynamo for the time being and explore the regulator option, which I wasn't aware of.
