Door Panel Gap
7 replies to this topic
#1 ac427
ac427
  • 739 posts
Posted 26 November 2023 - 07:25 PM
Sorry for yet another question thread. I have been looking at quite a few Mini pix and was wondering if the larger gap at the top of the door and the leading edge was normal in the pic above?
Some pix seems so show the same whilst other show it to be a closer fit.
#2 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,189 posts
  • Name: Neil
Posted 26 November 2023 - 07:39 PM
No its not normal for a gap that big.
Now its possible the door has been reskinned or bought second hand. Whenever i reskin a door for my self, i fit the carcass in the door frame first to get the best all round gap then add the skin.
#3 ac427
ac427
  • 739 posts
Posted 29 November 2023 - 06:48 PM
Could it be through accident damage?
The shoulder of the door seems to line up perfectly with the shoulder of the shell.
It just seems strange that it fits the bodyshell aperture front ad rear but not on the top or the front diagonal.
I just thought of Jaws. Am i going to need a bigger door?
Is it repairable?
#4 sonikk4
sonikk4
  • 16,189 posts
  • Name: Neil
Posted 29 November 2023 - 07:14 PM
Is it repairable?
Is it repairable, i will say yes as i did something similar on my lads car.
When i reskinned his car doors they were pants to coin a phrase. Defo not original to the car and needed major work. Now i did go OTT with his car with regards to panel gaps etc and maybe a tad too much.
97ca80e624295d5af6abb142d7a5c6c115a5682b
2ee0c06fee882647590750c81afcc5eb76dee743
051f1d4197e9a0fae43cb6f45a47f10234659cf1
afb1acbcc01177b4dfeb81d1001eacc5d4d50311
The other side of the car
11c77a413babcdb919b622334bb4aa4799886e30
a679f79134ffde7d067160ea69abb0bb47dc490f
ecdab911642c74447fa0120c2def0e15849bf562
84206e0e0a7e5bd43d16debd331dd2f666980a5e
Finished result
a9dd98964f1867b428e68adf771e7c7dc8efbee1
Now did i need to go this far, probably not but i was up for it and we were pleased with the result.
BUT will the window fit, that is the question but nothing has changed other than the height of the frame. And to be brutally honest i really should have started off with two better doors as like the rest of the car they had been bodged to death and back.
Heritage skins by the way as when i tried magnum it was even worse. Now since then having restored a mini Special and my own Clubby, both very extensively restored, the gaps were far far better as they were the original doors that came with the cars. I stll added some welding filler rods to the edges of the door gaps for One Pound Coin gaps but nothing to the frames.
So having digressed slightly here, the frames are spot welded to the door carcass and could in theory be split from the carcass and lifted slightly to close the gaps. BUT again a lot of work and i mean a chunk of work. Personally if you are that concerned i would look at removing the skin, repositioning the door carcass in the aperture and then offer up the door skin until im happy with everything.
Like this
c7f34c54c96bc013cc7bb742fba6b08c0f4220e8
gaps at the top of the door
2504e2c1d91b5843e977c3ec76aaead497d2dbbc
Now i did spend some time tweaking, bending, applying some science where needed with my calibrated 2lb club hammer but finished result
792d11e22fbdec60585a5d176f80756009769788
#5 ac427
ac427
  • 739 posts
Posted 29 November 2023 - 10:42 PM
Blimey Neil, That is some great (and a lot of) work. Thanks for the detailed response.
I guess if you can DIY it then good but i'm short on the skill, tools and space to perform these sorts of tasks.  I suppose a specialist Mini body shop would be able to do it for a fair 'ol whack.
The guy who is selling it, says he wants to reduce his Mini collection. So i guess you would sell the runt of the litter as it were first.
Edited by ac427, 29 November 2023 - 10:43 PM.
#6 sonikk4
sonikk4
  • 16,189 posts
  • Name: Neil
Posted 30 November 2023 - 09:51 AM
Ulitmately if the door is not whistling when you are driving along or leaking in water then i would live with it.
But looking at your picture i cannot see the rear of the door skin edge. If this is really close then it may need shims removing from the hinges (if fitted) and then you could tweak the height of the door slightly to try and reduce the gap. Now that is a cheap fix, just needs some basic tools then.Nothing specialist.
#7 ac427
ac427
  • 739 posts
Posted 02 December 2023 - 02:04 PM
Thank you.
Here are a couple more and a passenger door shot one showing presumably what it should look like :D
Edited by ac427, 02 December 2023 - 02:06 PM.
#8 sonikk4
sonikk4
  • 16,189 posts
  • Name: Neil
Posted 02 December 2023 - 05:18 PM
So looking at those pictures your door could go slightly fwd and up. The swage line at the rear of the door is lower than the swage line on the quarter panel.
Now what you need to do is look to see if there are any shims under the hinges where they attach to the A post. If so then I would take out the top one to start with. And then at the same time see if there is enough slack in the A post mounting holes to raise the door.
If there isn’t any slack in the holes the. You can slot them. This will them allow you to raise the door. It does t need a lot to make a big difference.
