Third Brake Light
#61
Posted 06 January 2025 - 07:53 PM
Tapped into drivers side rear light connector, up to C-pillar and out the rear demister opening on the trim, tuck into rear screen seal, then 3d printed bracket/tags wrapped in cloth tape and tucked up under screen seal
#62
Posted 15 January 2025 - 08:57 PM
Here is mine: Is is some 9" long. A thin strip of single LEDs so very unobtrusive. The LEDs are very bright. I believe it works quite well! - I wish it did not look so modern... but it works.
I've been happy with the LEDs in the lower brake lights. These have also increased brightness. I feel better about being seen at night now...
* Just noticed the mess I had going. I was just finishing-up the install, so not a glamour shot!
Edited by Blumeanie, 15 January 2025 - 11:28 PM.
#63
Posted 19 January 2025 - 11:10 AM
#64
Posted 19 January 2025 - 11:21 AM
I have fitted a third brake light to both my 1966 and my 1990, both were fiddly, just takes patience.
I’m not an expert, but running wires up from the rear lamp will pay dividends in the long run in my humble opinion.
Get stuck in, I actually quite enjoyed it!
I have an Olight set on one of my bicycles, the rear light is the size of a fun-size Mars Bar. It is as bright as the sun, runs for days of use before it wants a usb top up of charge. The reason I raise this is that it has a built in accelerometer and acts as a brake light. I know this is a solution to a problem that doesn’t exist, but I don’t want to run additional wiring from the boot up to the top of the window and am now thinking about how I could adapt one.
Edited by beardylondon, 19 January 2025 - 11:24 AM.
#65
Posted 19 January 2025 - 12:57 PM
A Hella 5239 is perfect but they would be difficult to get outside of Australia and New Zealand. Unfortunately I do suspect they have been discontinued like a lot of useful Hella products.
Check with Daniel Stern. He might still have some in stock. https://www.danielst...s/products.html
#66
Posted 19 January 2025 - 05:03 PM
An inertia switched light would at least not dazzle when you're waiting in traffic.
#67
Posted 19 January 2025 - 06:32 PM
And just to finish my lighting/visibility upgrade - the rear fog lamp got fitted today. It is a WIPAC clear indicator lens with an extra bright red P21W LED bulb to match the others. The stainless centre bracket came from John at JB Fabrication.
From tasty classics?
#68
Posted 19 January 2025 - 06:45 PM
#69
Posted 19 January 2025 - 11:45 PM
I fished a strip of acrylic mirror out of the bin, just this morning, with the same idea in mind. Uncanny coincidence
