Third Brake Light
75 replies to this topic
#46 Littlefella
Littlefella
  • 43 posts
Posted 20 December 2023 - 06:05 PM
Pic & Video attached
https://imgur.com/a/KCXPqxx
#47 Quinlan minor
Quinlan minor
  • 1,171 posts
  • Local Club: LSMOC
Posted 20 December 2023 - 06:12 PM
Looks good.
What's it like on the inside?
#48 Littlefella
Littlefella
  • 43 posts
Posted 20 December 2023 - 06:16 PM
I will take a couple of photos tomorrow in the daylight. Pretty tidy though. Removed the rear seat belt fixing/widow catch/trim cover and ran cable the same route as the washer tube.
#49 IronmanG
IronmanG
  • 1,228 posts
  • Local Club: Box hill. Lsmoc member
Posted 20 December 2023 - 06:35 PM
I've ordered mine so looking forward to fiting that
#50 beardylondon
beardylondon
  • 1,529 posts
Posted 20 December 2023 - 07:19 PM
Looks good!
You didn’t fancy installing indicators too then?
#51 Littlefella
Littlefella
  • 43 posts
Posted 20 December 2023 - 07:31 PM
Looks good!
No thought I would just go with brake light only for now! 😉
Edited by Littlefella, 20 December 2023 - 07:33 PM.
#52 Littlefella
Littlefella
  • 43 posts
Posted 21 December 2023 - 04:50 PM
Looks good.
#53 Littlefella
Littlefella
  • 43 posts
Posted 21 December 2023 - 04:56 PM
Sorry some IT issues there!
@Quinlan minor some photos attached
https://imgur.com/a/wwL3QyZ
#54 beardylondon
beardylondon
  • 1,529 posts
Posted 21 December 2023 - 05:29 PM
You’re going to probably want to mask the red off in the inside, otherwise, especially at night it could get quite annoying and distracting
#55 Quinlan minor
Quinlan minor
  • 1,171 posts
  • Local Club: LSMOC
Posted 21 December 2023 - 07:36 PM
Thanks for that, Littlefella.
#56 ctmandu
ctmandu
    Just On Tickover
  • 9 posts
Posted 22 December 2023 - 03:47 AM
here is mine.
#57 unburntfuelinthemorning
  • 1,983 posts
Posted 11 May 2024 - 12:21 PM
I would say definitely best not to use excessively bright lights anyway you won't make yourself any more visible all it will do is p.ss off everyone...it's just unnecessary beyond a point (in some cases just blatantly inconsiderate)
The same applies to cyclists who think brighter lights are always better.  As you say brightness is good - up to a point.
#58 Blumeanie
Blumeanie
  • 156 posts
Posted 05 January 2025 - 08:43 PM
2000 Cooper Sport here. - It did not come with a third brake light from the factory.
I do not find the ROVER factory version very appealing as it is a bit chunky and sits low on the shelf. For a mini; the third brake light needs to be on the top edge of the rear window to be most effective with the extremely large vehicles running around these days!
I have ordered a thin LED strip which should be pretty invisible until it lights up. This will be placed at the top center edge of the rear glass.
I enjoyed seeing all the various solutions so far on here.
I would appreciate insight into how those of you who have added a third brake light have proceeded to do your connections? Di  you tap into the wiring? did you tap in at the rear light fixtures? or did you tap into the fuse? I would appreciate the insight as I am horrible at electrics.
Thanks in advance!
Edited by Blumeanie, 05 January 2025 - 08:45 PM.
#59 beardylondon
beardylondon
  • 1,529 posts
Posted 05 January 2025 - 10:09 PM
I tapped into the brake light circuit at the rear light unit, no need to run from fuse box. You obviously only need to tap in on one side.
I then ran the cables up/down the c pillar.
Make sure you use the correct thickness cable, I can’t remember off the top of my head, someone on here will be able to tell you the correct size.
#60 Davidmt
Davidmt
  • 204 posts
Posted 05 January 2025 - 10:22 PM
As above - just tap the existing brake light wiring at the back of the light units.  Suspect the side away from the fuel tank will usually be easier to access - then run up your wires to where ever you are attaching your 3rd brake light.  Cable size should be less of a worry if you are using an LED as they don't draw a large current.  Regular low amp 12v wire should be more than suffient.  I keep a separate list of wire colours and fuses (if used) so any subsequent owner can try and follow my incremental wiring  :-) .
Edited by Davidmt, 05 January 2025 - 10:22 PM.
