Third Brake Light
68 replies to this topic
#31 Shooter63
Shooter63
  • 980 posts
Posted 16 December 2023 - 09:50 AM
I've bought what I think is a retro looking lamp for my MK1 it takes a standard indicator type bulb ba15s, is there a maximum wattage you are allowed to put in? As I've found some pretty high wattage bulbs available ie 80w if I use a LED type.
Shooter
#32 stuart bowes
stuart bowes
  • 1,952 posts
Posted 16 December 2023 - 07:17 PM
https://www.legislat...chedule/12/made
says 15-36w max, which I assume is based on incandescent ratings, so you'd be looking for an LED equivalent around 18w max
I would say definitely best not to use excessively bright lights anyway you won't make yourself any more visible all it will do is p.ss off everyone behind you every time you press the brake pedal
not to always be that one that comes along and moans about bright lights but it is a real bug bear of mine, it's just unnecessary beyond a point (in some cases just blatantly inconsiderate)
Edited by stuart bowes, 16 December 2023 - 07:20 PM.
#33 Littlefella
Littlefella
  • 40 posts
Posted 18 December 2023 - 06:49 PM
I've just taken delivery of this to install.Self adhesive and can be cut to length.
https://amzn.eu/d/iteb5uy
https://imgur.com/a/k9YtIB3
#34 stuart bowes
stuart bowes
  • 1,952 posts
Posted 18 December 2023 - 07:07 PM
24w possibly slightly off the brighter end of scale there but not quite all the way to 'outrageous' ?
I like the simple and effective style though, discrete when off.. pics when done ?
Edited by stuart bowes, 18 December 2023 - 08:01 PM.
#35 beardylondon
beardylondon
  • 1,449 posts
Posted 18 December 2023 - 07:51 PM
Very good, and good luck, post some pics when its done!
#36 Quinlan minor
Quinlan minor
  • 1,128 posts
  • Local Club: LSMOC
Posted 18 December 2023 - 08:28 PM
I'm going to try this one,too.
#37 Littlefella
Littlefella
  • 40 posts
Posted 18 December 2023 - 08:35 PM
@Stuart Bowes & @beardylondon, will definitely post pics when done
#38 IronmanG
IronmanG
  • 1,213 posts
  • Local Club: Box hill. Lsmoc member
Posted 18 December 2023 - 09:20 PM
That looks ideal. I feel like this is a div question. Does it go on the inside.
#39 stuart bowes
stuart bowes
  • 1,952 posts
Posted 18 December 2023 - 09:28 PM
be like superman put it on the outside
main-qimg-12dd1fc7807c93bcc761838bcef55d
Edited by stuart bowes, 18 December 2023 - 09:28 PM.
#40 IronmanG
IronmanG
  • 1,213 posts
Posted 18 December 2023 - 09:40 PM
On the picture it say outside. That's why I'm asking
#41 IronmanG
IronmanG
  • 1,213 posts
Posted 18 December 2023 - 09:44 PM
Attached File  Screenshot_20231218_214116_Samsung Internet.jpg   25.73K   4 downloads
#42 stuart bowes
stuart bowes
  • 1,952 posts
Posted 18 December 2023 - 09:48 PM
i was only mucking about
but it looks to me like the sticky strip is on the same side as the light output. which suggests inside fixing?
yeah I see the note you mean, does also say "can be directly affix it" lol so possibly just an 'Engrish' translation error
Edited by stuart bowes, 18 December 2023 - 09:53 PM.
#43 IronmanG
IronmanG
  • 1,213 posts
Posted 18 December 2023 - 09:54 PM
Haha the old Chinglish.
Ye it does look like it's a question mark profile with the double sided on the bottom leg
#44 beardylondon
beardylondon
  • 1,449 posts
Posted 19 December 2023 - 09:59 AM
deffo on the inside, on mine I hung it inside and also inside some trucking and made brackets to attach to the rear screen rubber
https://www.theminif...and-indicators/
#45 Bobbins
Bobbins
  • 1,465 posts
Posted 19 December 2023 - 10:16 AM
If you fit it on the outside where are you going to run the cables ….?
5 user(s) are reading this topic
0 members, 5 guests, 0 anonymous users
