Mk 2 Door Hinge Question
Best Answer GraemeC , 10 November 2023 - 01:35 PM
1/4"UNF is 28tpi, so your measurements weren't far off!
Go to the full post
5 replies to this topic
#1 Gnielsen
Gnielsen
  • 21 posts
Posted 10 November 2023 - 11:56 AM
In the course of a restoration I have found that my door hinges would benefit from having their threads (for studs and cap screws) cleaned up by chasing the threads with a tap. My question is what is the thread pitch of the door hinge studs/cap screws? I measured 1/4” x 27 threads per inch, but it is such a weird pitch that I doubt my measurement is correct.
#2 DeadSquare
DeadSquare
  • 3,088 posts
Posted 10 November 2023 - 12:59 PM
It is 1/4"
Look up Unified Fine thread and Unified Coarse thread, which were used on Minis.
#3 stuart bowes
stuart bowes
  • 2,075 posts
Posted 10 November 2023 - 01:18 PM
minispares seems to suggest 1/4" UNF for both external and internal hinge bolts
https://www.minispar...|Back to search
https://www.minispar...k to search#tkc
they're usually accurate with info
#4 GraemeC
GraemeC
  • 7,431 posts
Posted 10 November 2023 - 01:35 PM   Best Answer
#5 bpirie1000
bpirie1000
  • Area Managers
  • 2,336 posts
  • Local Club: Amoc
Posted 10 November 2023 - 02:47 PM
Used to really brass me off the different bolts that were used. Then I was shown the light..
Into cast thin threads..
Into alloy. Thicker threads...
And that was my lightbulb moment..
As for into Nutts.. well that it a free for all.....
#6 DeadSquare
DeadSquare
  • 3,088 posts
Posted 10 November 2023 - 08:46 PM
You need a brighter light bulb.
Cylinder head studs, Rocker pedestal studs, Thermostat housing studs, etc:, have a coarse thread on one end where they screw into cast iron.
