Austin Mini And It`s Accident Safety.
3 replies to this topic
#1 Mini-Hazel-Nut
Mini-Hazel-Nut
  • 607 posts
  • Local Club: Birmingham Mini Owners
Posted 09 November 2023 - 10:37 PM
Just a short video with a few home truths in it, but don`t let that put you off owning the greatest ever car!
#2 DeadSquare
DeadSquare
  • 3,080 posts
Posted 09 November 2023 - 11:18 PM
Good point about the fuel filler.
I didn't do much rallying, it was somehow a bit unsatisfactory to think that a corner should have been taken faster, but no next time with a chance to do better, as on a race track, so on my 1071 S, I moved the fuel filler from the outside edge of the tank to the other side of the seam, so that it pointed to the rear through a repositioned hole, to give myself a bit more confidence, in the event of a roll.
Abingdon noticed it, commented wisely about it, but said that Longbridge wouldn't incorporate it in the proposed Mk2 rear panel, because they knew that the unions would have demanded a revised assembly timing.
#3 bpirie1000
bpirie1000
  • Area Managers
  • 2,316 posts
  • Local Club: Amoc
Posted 10 November 2023 - 07:15 AM
Always a case of what some other silly driver does moremthan what the mini driver does....
#4 mab01uk
mab01uk
  • 12,370 posts
Posted 10 November 2023 - 09:59 AM
BMC Mini Crash Tests (1961)
"Several shots of Mini cars with two crash-test dummies inside it crashing head on into a large concrete block. Some shots in slow motion. Still shot showing the effects on the car crashing at 25, 30 and 38 miles an hour."
https://www.britishp...m/asset/194639/
