850 Magic Lilly
73 replies to this topic
#61 gaspen
gaspen
  • 938 posts
Posted 23 July 2024 - 06:40 PM
Heelboard married with the floor panel with upgraded welding skill  :D  Voltage up, wire speed down
Maybe the plugwelds are too dense but strong
Attached File  20240720_101942.jpg   79.42K   1 downloadsAttached File  20240720_090840 (1).jpg   38.21K   2 downloads
I've fabricated some repair patches for the rear arches
Attached File  20240704_110649.jpg   36.18K   3 downloads
Something is not aligned here  O_O  Other side is good, outer sills are not welded yet
Any ideas ?
Attached File  20240721_102257.jpg   71.79K   2 downloads
#62 gaspen
gaspen
  • 938 posts
Posted 11 August 2024 - 10:49 AM
The floor is in finally  :proud: Apart from this achievement I've made much littel repairs hence of the slow progress.
Attached File  20240805_172520.jpg   42K   1 downloadsAttached File  20240806_170728.jpg   58.34K   2 downloads
Ctrl-X > Ctrl-V for the boot floor pieces for original look  :D
Attached File  20240805_124729.jpg   19.03K   3 downloads
And a very important piece installed with rivnuts :  The Mirror
Attached File  20240806_143318.jpg   60.02K   1 downloads
#63 84 City E
84 City E
  • 54 posts
Posted 11 August 2024 - 02:37 PM
The low compression, did you turn the engine to get oil pressure up first?
Did you put a little oil down the bores before compression testing?
Assuming the engine has stood not running for some time, some oil down the bores and turn over until you have oil pressure (or if rocker cover off oil coming up to the valve train decently)
Then try another compression test, even maybe get it running and let it run a while then cool before doing the compression check.
Diving straight to checking compression of an engine that’s sat will not give you sensible readings
#64 gaspen
gaspen
  • 938 posts
Posted 11 August 2024 - 05:23 PM
The engine already dismantled. The pistons were collapsed, the bore-to-piston gaps were huge. It had to be rebored to 1st oversize.
And the surfaces under the main bearing caps are pitting from rust. Because of this the crank is seizing when the bolts torqued.
I will have an other trip to the machine shop
#65 84 City E
84 City E
  • 54 posts
Posted 12 August 2024 - 06:43 AM
I see, the thing really was worn out then.
Have read your whole thread now, the car looks to be in good hands, you are doing great work
#66 gaspen
gaspen
  • 938 posts
Posted 28 August 2024 - 03:25 PM
And the boot floor is its place, even the rubber mat fits perfectly  :D  I've primed all fixed panels with 2k epoxy.
I had to cut and weld the front part of the floor cross member so I've lost the seat bracket nuts but purchased some UNF rivet nuts.
Attached File  20240826_103731.jpg   46.08K   2 downloads
 Attached File  20240827_115537.jpg   70.44K   1 downloads
Attached File  20240809_081121.jpg   49.68K   2 downloads
Attached File  20240828_100853.jpg   55.97K   2 downloads
#67 gaspen
gaspen
  • 938 posts
Posted 08 September 2024 - 06:21 PM
Who said it's small ? It's like a cab !
Attached File  20240907_151634.jpg   29.76K   5 downloads
Edited by gaspen, 08 September 2024 - 06:23 PM.
#68 gaspen
gaspen
  • 938 posts
Posted 23 September 2024 - 03:46 PM
Out on the ligtht with the fresh sprayed primer  ;D
Attached File  20240914_131210.jpg   78.9K   3 downloads
Time to focus on the front end. I've recycled the old valve guides for "special tool" : wing positioner   :D
Attached File  20240923_154727.jpg   80.67K   6 downloads
Attached File  20240923_133256.jpg   30.26K   9 downloads
Door gaps still look fine
Attached File  20240923_165920 (1).jpg   69.65K   10 downloads
#69 gaspen
gaspen
  • 938 posts
Posted 10 October 2024 - 03:21 PM
Do you see ?
Attached File  20241010_152257.jpg   57.58K   13 downloads
#70 gaspen
gaspen
  • 938 posts
Posted 18 October 2024 - 10:54 AM
I accepted my mistakes so let the good times roll  ;D
The A-panels I fitted are the Minispares's upgraded version. They fit nicely
https://www.minispar.../ALA5661MS.aspx
What an ass !  :kiss:
Attached File  20241012_154600.jpg   33.98K   0 downloads
Think simple !
Attached File  20241017_103952.jpg   32.23K   1 downloads
Attached File  20241018_113237.jpg   39.31K   0 downloads
So much fun I have
Attached File  20241016_115157.jpg   55.43K   1 downloads
Slowly she manifests
Attached File  20241018_112828.jpg   71.73K   1 downloads
If you interested in all the story here is the link
https://photos.app.g...k71uE8MpDBoVez6
Edited by gaspen, 18 October 2024 - 01:58 PM.
#71 gaspen
gaspen
  • 938 posts
Posted 19 October 2024 - 03:17 PM
With the rotisserie I can not fit the bonnet  so I placed the body on the fixed stand and started the fun with the front end   :shifty:
Of course the front subframe is mounted in its place.
Attached File  20241019_131402.jpg   72.55K   1 downloads
I bought aftermarket wings in a local shop earlier. They made by Rhibo (MaxiCar) Well they look fine for 1st glance but both need "some" adjustment. The left side is acceptable but the right one is a nightmare.
I welded up the corner piece at the headlight opening which was spotwelded originally. Maybe saved a rust collection spot  :gimme:
Attached File  20241019_134337.jpg   27.76K   2 downloads Attached File  20241019_142159.jpg   28.67K   0 downloads
Before sunset I've made the bonnet's rear curve prettier with the shrinker-stretcher tool
Attached File  20241019_134653.jpg   33.3K   1 downloads
Much better
Attached File  20241019_141834.jpg   84.23K   1 downloads
#72 gaspen
gaspen
  • 938 posts
Posted 11 March 2025 - 11:48 AM
After winter hibernation I am back again  :proud:
I've put together the engine and box, also installed a chain tensioner. It was necessary to straighten the crank, but now it rotates nicely.
Maybe you read my topic about my worries about the bodywork  Mistakes - Mini Chat - The Mini Forum
Well then I measured it with a laser tool and it looks like that the subframe fixing point are in the correct positions.
For first view it looked like the doors are fine, but still I removed the skins and I did this well.
And I will need many patience to assemble the front end  O_O
Also I collected some spare CIPA mirror
Question : which one is the correct hubcap for this Mini ?
Attached File  20241124_115625.jpg   67.6K   0 downloadsAttached File  20241201_153405 (1).jpg   41.38K   0 downloads
Attached File  20241107_101052.jpg   108.64K   0 downloads
Attached File  20250310_091743.jpg   30.75K   0 downloadsAttached File  20250310_101928.jpg   25.8K   0 downloads
Attached File  20250311_115838 (1).jpg   66.62K   0 downloads
#73 colinf1
colinf1
  • 1,013 posts
Posted 11 March 2025 - 01:16 PM
Links to some 1970's brochures
http://www.minipassi...0 1000 1970.pdf
#74 gaspen
gaspen
  • 938 posts
Posted 15 March 2025 - 09:10 AM
I worried about the front-end but I solved it with a simple step : I've placed the front panel half a hole lower and now the wings fit almost perfectly.
Attached File  20250314_110243 (1).jpg   19.96K   0 downloadsAttached File  20250314_110544 (1).jpg   64.37K   2 downloads
Question : I bought this timing cover but there is no breather and timing markers on it.  Also the "stiffeners" beetween holes are deeper.
From what car it comes from ?
Attached File  20250314_114455.jpg   39.7K   2 downloads
