850 Magic Lilly
73 replies to this topic
#46 johnR
johnR
  • 2,297 posts
Posted 22 March 2024 - 08:57 AM
Nice work - and very envious of your sunshine!
#47 gaspen
gaspen
  • 938 posts
Posted 23 March 2024 - 05:05 PM
Re-fabricated the inner wing end repair panel because i wasn't satisfied with the 1st one. This time I bent the flange with my shrinker tool for a nice curve and welded to the other piece. Much better shape  :shifty:
Attached File  20240323_120121.jpg   46.8K   2 downloads
I drew my plans where to cut the toe-board but not sure what to do... This piece has more rust inside than outside  O_O
Attached File  20240323_162113.jpg   83.07K   4 downloads
And I purchased a pair of aftermarket wings. They fit suprisingly good for the heritage front panel, just some little adjusments will need
The wings made my RHIBO ( or MAXICAR)
Attached File  20240323_123432.jpg   76.91K   3 downloads
#48 Viktor
Viktor
  • 653 posts
Posted 24 March 2024 - 07:15 PM
Ummm, interesting Gaspen. Doing my front panel and wings now, so I was thinking on doing the same as you; welding the wings and front panel together and get them in one go into the car. I will be following...
Victor.
#49 gaspen
gaspen
  • 938 posts
Posted 25 March 2024 - 06:07 AM
Victor.
They are not welded yet. Just test fitted with some clamps.
But when I've made my Authi I welded them into one piece after carefully aligned them on the car. Then I marked the postions with adhesive tape.
Attached File  IMG_20201230_211028.jpg   87.31K   0 downloads
#50 Viktor
Viktor
  • 653 posts
Posted 25 March 2024 - 06:07 PM
Cheers Gaspen, that's helpful.
#51 gaspen
gaspen
  • 938 posts
Posted 31 March 2024 - 05:32 PM
I am working in slow motion on this car  :D
I've made the patch panel for the left side of the toe board. It's a good ide to keep the original pieces for copy or template
Attached File  20240326_104938.jpg   102.68K   1 downloads Attached File  20240326_110518.jpg   71.38K   1 downloadsAttached File  20240326_115556.jpg   68.58K   0 downloads
On the holidays I have to be quite so I tried if I can make a lift bracket. Yes I can  :proud:
Attached File  20240331_101621.jpg   70.22K   2 downloads
The door frame and the stiffener spot-welded into one assembly
Attached File  20240331_133209.jpg   48.1K   1 downloads
And I got some experience with M-Machine panels. They are "heavy" , I mean made from pretty strong and thick steel but here I had some issues.
It is the front quarter piece of the floor. I trial fitted it but it did not fit very well. So I started to measure.
The vertical part is 9 cm high at the front (as the original floor) but only 8.4 at the end. It came out that the bending is on the wrong place.
I draw the correct bending with a pencil. After some hammering it's much better.
Attached File  20240331_165040.jpg   26.27K   2 downloads Attached File  20240331_165118.jpg   28.7K   0 downloads Attached File  20240331_164926.jpg   20.26K   1 downloads
Attached File  20240331_173300.jpg   24.91K   0 downloadsAttached File  20240331_175522.jpg   24.24K   2 downloads
#52 gaspen
gaspen
  • 938 posts
Posted 03 April 2024 - 05:57 AM
Could anybody confirm that the bottom edge of the toe-board must be a straight line ?  And the toe-board is basically a flat surface ?
Attached File  20240402_173316.jpg   72.42K   1 downloads
#53 gaspen
gaspen
  • 938 posts
Posted 08 April 2024 - 01:51 PM
Everyday I give myself an achievable task. Today I repaired the upper corner of the inner wing - from one piece. It was easier than I thought.
Attached File  20240318_163835.jpg   38.03K   2 downloadsAttached File  20240408_090527.jpg   54.64K   1 downloadsAttached File  20240408_102631.jpg   57.42K   3 downloadsAttached File  20240408_112852.jpg   50.22K   2 downloads
Edited by gaspen, 08 April 2024 - 01:52 PM.
#54 gaspen
gaspen
  • 938 posts
Posted 22 April 2024 - 05:55 AM
I decided to make a new floor instead of patching. As I already have the tunnel and outer sills I ordered two half floors from M-Machine.
Some tension remained in the floor panels, I hope it will be straight after welding
Similar to the upper corner I repaired the front of the inner wings.
Using the old pieces as templates I fabricated the rear valance closing pieces and the subframe mount stiffener
And finally I can not dance on the floor for a while...
Attached File  20240421_173254.jpg   66.64K   1 downloads
Attached File  20240409_094840.jpg   46.62K   0 downloadsAttached File  20240409_120025.jpg   34.92K   0 downloads
Attached File  20240421_130456.jpg   57.23K   3 downloads
Attached File  20240418_171818.jpg   96.77K   2 downloads
#55 gaspen
gaspen
  • 938 posts
Posted 26 April 2024 - 04:21 PM
Patchwork continued....
Attached File  20240424_103305.jpg   71.48K   0 downloadsAttached File  20240425_113105.jpg   65.3K   0 downloads
Attached File  20240426_165202.jpg   45.65K   1 downloadsAttached File  20240426_174423.jpg   48.72K   1 downloads
#56 gaspen
gaspen
  • 938 posts
Posted 30 April 2024 - 06:22 AM
Found some worms here and there....
Attached File  20240429_174407.jpg   90K   0 downloads
...fortunately it comes off easily with strip disc
Attached File  20240429_182402.jpg   78.23K   0 downloads
Test fit of the tunnek proofs that I am not out of alignment  :gimme:
I was not forehande enough and I drilled the front of the tunnel from outside - the bracing didn't allow it form inside. Now it looks like a sieve
Should I weld up the holes and drill new ones ? Or use them for the tunnel welding ? I prefer a nice pattern of holes, but weld up will harden the material...
Attached File  20240429_164956.jpg   80.81K   0 downloads
#57 gaspen
gaspen
  • 938 posts
Posted 03 May 2024 - 05:30 PM
Well.... finally I removed the boot floor from its place and I faced with days of grindig and still "some" rust.  Fast decision made : ordered a new one  O_O
So I focused to the floor. First I cleaned the crossmember to see where to cut. Then I made the repair sections. Some adjustment was needed as the M-Machine floor panels are a little bit different. Using lower settings on the welder and with the help of air gun I can avoid distortion  :shades:
Attached File  20240502_150537.jpg   38.48K   1 downloads Attached File  20240502_173639.jpg   79.09K   0 downloads
The tunnel needed some care also
Attached File  20240503_131604.jpg   41.56K   0 downloads Attached File  20240503_140602.jpg   41.23K   2 downloads
After finished the crossmember I assembled the floor and cut the welding line
Attached File  20240503_145814.jpg   81.24K   4 downloads
#58 gaspen
gaspen
  • 938 posts
Posted 27 May 2024 - 06:23 PM
I've made lots of (some) small steps forward. While I am waiting for the new wings I started repair of the rear end because I would like to install the boot floor first.
Attached File  20240513_170800.jpg   55.4K   3 downloadsAttached File  20240525_135736.jpg   55.5K   1 downloads  Attached File  20240523_113920.jpg   60.76K   2 downloads
Left door step welded up. The gaps looks fine.
Attached File  20240524_145457.jpg   79.79K   1 downloads
One day the wind blew the rain into the bare floor panel so I decided to spray it with epoxy primer
Attached File  20240527_164805 (1).jpg   76.82K   3 downloads
#59 gaspen
gaspen
  • 938 posts
Posted 09 June 2024 - 07:27 PM
Everyone make mistakes, now it's my turn   :D
I was too lazy when aligned the floor panels for welding. I wanted to fit the floor but it won't fit very well. Then I noticed my mistake : the left side of the floor is  ~1cm narrower
I had no choice : cut the left hand side of the floor and weld a widening piece on the full length...
Attached File  20240607_093921.jpg   26.8K   0 downloads
Attached File  20240607_095538.jpg   48.32K   0 downloads
Attached File  20240607_111438.jpg   37.84K   0 downloads
#60 gaspen
gaspen
  • 938 posts
Posted 29 June 2024 - 08:38 PM
After some "tweaking" on the floor I can move on slowly.
I've stripped the paint from the doors and fortunately they are in very good shape because somebody sprayed cavity protection inside in the past. Blessed be his name !  LH side has a little bump, I hope I can straighten it
Attached File  20240628_135320.jpg   62.75K   1 downloadsAttached File  20240627_181204.jpg   60.82K   2 downloads
With less fortune I have these rust worms on the panels. With cleaning disc it's easy to remove them but they 'live' there under the paint.
Attached File  20240620_162656.jpg   33.54K   4 downloads
After cleaning and a good degrease I sprayed 2K epoxy on some areas. The roof and the rain gutter are in good condition also, did not
Attached File  20240622_120144 (1).jpg   76.94K   2 downloads
And the not-so-accurate pressings on the floor panels gave me some headache. I've just searched 2 hours what I f...ed up with the outer sills. Finally I founf that these pressing are 10 mm closer to the edge on one side then on the other  O_O
Attached File  20240622_181141.jpg   23.88K   1 downloadsAttached File  20240622_181121.jpg   22.62K   1 downloads
