850 Magic Lilly
72 replies to this topic
#31 gaspen
gaspen
  • 908 posts
Posted 26 February 2024 - 06:44 PM
After some fighting with the selector for mis-alignment I finally assembled the gearbox. New QL5000 driveshaft coupling installed to keep original as possible.
Attached File  20240211_160957.jpg   32.52K   1 downloads Attached File  20240226_085426.jpg   62.36K   3 downloads
Also I prepared the pistons and rings which had ZERO gap in the rebored cylinders. I filed them to specification.
Not so important on a 850 engine, but suprisingly the weight of the pistons were very close to each other - all is less than 1 gramm range
Attached File  20240217_153412.jpg   36.36K   2 downloads  Attached File  20240217_171158.jpg   69.17K   1 downloads
I also ask the machine shop to insert valve seats for the exhausts. At home I noticed some difference at the valves : they are not uniform in length
Attached File  20240214_102908.jpg   57.19K   0 downloads
#32 gaspen
gaspen
  • 908 posts
Posted 03 March 2024 - 09:06 PM
As the spring comes I go for the bodywork. First I made two A-panels  :D
Attached File  20240302_151014.jpg   61.13K   4 downloadsAttached File  20240302_113349.jpg   33.35K   7 downloads
Somebody in the past  sprayed cavity wax into the sills. Then an "expert" put on some oversills made from gutter : it was so thin that I could tear it with my hand.
Attached File  20240303_145649.jpg   90.55K   5 downloads
#33 sonscar
sonscar
  • 2,962 posts
Posted 04 March 2024 - 11:06 AM
Once upon a time minis were plentiful and cheap.Repairers were thinner on the ground who could weld.Few were interested in expensive repairs and sought the minimum cost to remain mobile.
Thankfully these cheap repairs enabled a reasonably healthy supply of repairable cars to survive so now with unlimited DIY tools we can rebuild them.Steve..
#34 gaspen
gaspen
  • 908 posts
Posted 10 March 2024 - 05:17 PM
Today I started to save the LH wing. I have a metal stretcher/shrinker tool so bending those curved flanges pretty easy but need some time and patience
There is a quarter piece on the wing around the headlamp which was spot welded in the factory. I will butt weld it after repair so I can prevent it from moisture.
Next time coming the flange that connects to the inner wing and the corner at the scuttle. This one looks pretty tricky  :ohno:
Attached File  20240310_100706.jpg   61.24K   0 downloads
Attached File  20240310_110319.jpg   63.98K   2 downloads
Attached File  20240310_125154.jpg   56.35K   2 downloads
Attached File  20240310_170041 (1).jpg   57.9K   2 downloads
#35 stuart bowes
stuart bowes
  • 2,047 posts
Posted 10 March 2024 - 05:23 PM
nice bit of fabrication there
#36 sonscar
sonscar
  • 2,962 posts
Posted 10 March 2024 - 06:44 PM
Excellent work,Steve..
#37 gaspen
gaspen
  • 908 posts
Posted 12 March 2024 - 11:50 AM
Advice please !
I started to build a rotisserie. The rear bracket is  pretty obvious, but not sure about the front. I plan to remove the front crossmember ( not sure, but there is rust inside ) so I don't want to fit it there. Also not really like to drill the bulkhead, but there is two holes there for the cable harness.
Is that are strong enough to hold the body ?
Attached File  20240306_170352.jpg   85.32K   1 downloads
Attached File  20240312_111014.jpg   26.85K   0 downloads
#38 gaspen
gaspen
  • 908 posts
Posted 16 March 2024 - 07:14 AM
Finally I put her on the rotisserie : let the good times roll !
Attached File  20240315_154719.jpg   95.5K   2 downloadsAttached File  20240315_160635.jpg   90.64K   2 downloads
#39 bpirie1000
bpirie1000
  • Area Managers
  • 2,316 posts
  • Local Club: Amoc
Posted 16 March 2024 - 07:22 AM
Remember the face mask.. leads to interesting hanky fills when you blow your nose....
Seen the central pipe mount to the inner dashboard shelf which I think may be is what your after.
Or have a look on here..
https://www.theminif...th-spit-design/
#40 gaspen
gaspen
  • 908 posts
Posted 16 March 2024 - 08:46 AM
Mask, gloves and glass are mandatory
Yes I found that pictures also but finally decided that I won't remove the front beam as it is not is so bad.
Now I am going to brace the body and next I will fabricate a template for the main fixinf points underneath.
#41 gaspen
gaspen
  • 908 posts
Posted 16 March 2024 - 05:39 PM
Bracing done, continue with demolition  :D
I've made a removable "template"  for the toe-board, I can acces that area for repair and put it back for alignment.
Until now I knew that the wing is not welded to the corner of the scuttle panel but it was spot-welded on both sides.
Riddle question : how could they access to that area with the spot-welder ?  O_O I mean before the rust  :D
Attached File  20240316_125501.jpg   87.61K   1 downloads
Attached File  20240316_171201.jpg   59.36K   0 downloads
Attached File  20240316_125727.jpg   55.85K   1 downloads
#42 Homersimpson
Homersimpson
  • 824 posts
Posted 17 March 2024 - 03:29 PM
I assume they used a single sided spot welder to do that joint.
#43 gaspen
gaspen
  • 908 posts
Posted 17 March 2024 - 04:23 PM
Okay, but for a good spotweld you will need some clamping force also...
Anyway I started clean up the inner wing to see how bad it is. It looks I can repair this area pretty easily but I have to make some template for the repair panel.
Attached File  20240317_164237.jpg   44.18K   0 downloads
#44 gaspen
gaspen
  • 908 posts
Posted 20 March 2024 - 06:32 AM
Yesterday I've made a scuttle closing panel using the old one for template. While it does not look bad but not perfect. At least I know what should I do better   :D
Attached File  20240319_170428 (1).jpg   61.76K   0 downloadsAttached File  20240319_183557.jpg   57.33K   0 downloads
About the spot welding : in this video you can see that the scuttle and the wings are welded together before final fitment
#45 gaspen
gaspen
  • 908 posts
Posted 21 March 2024 - 05:44 PM
Every day a little progress and some ferrous oxide
Attached File  20240321_154416 (1).jpg   89.52K   0 downloads
That's why I like heritage panels : they just fit
Attached File  20240321_160416.jpg   73.56K   1 downloads
Test fit the DIY repair panel - could be better...
Attached File  20240321_180412.jpg   41.83K   1 downloads
