850 Magic Lilly
70 replies to this topic
#1 gaspen
gaspen
  • 882 posts
Posted 04 November 2023 - 05:10 PM
Well, I bought the second one : a 1971 850  :kiss:
She is a little bad here and there but pretty original and not molested - probably because of her age  :D
I showed and asked some info about her in the chat area 850 - Mini Chat - The Mini Forum
Here you can follow the "update" if you interested.
Attached File  20231026_105412.jpg   45.55K   5 downloads
Attached File  20231026_111402.jpg   67.91K   0 downloads
Attached File  20231026_111541.jpg   39.76K   4 downloads
Attached File  20231029_100235.jpg   85.9K   10 downloads
Attached File  20231029_101609.jpg   37.73K   9 downloads
Attached File  20231029_153128.jpg   35.52K   8 downloads
Attached File  20231029_112346.jpg   76.62K   5 downloads
Attached File  20231029_101609.jpg   37.73K   7 downloads
#2 DeadSquare
DeadSquare
  • 3,040 posts
Posted 05 November 2023 - 12:02 PM
The late 60s / early 70s were not good years for Minis.
The accountants were economising on paint, bolstered by the notion that if the car rusted away quickly, drivers would have to buy another one.
It worked brilliantly ......................... for Honda.
#3 johnR
johnR
  • 2,291 posts
Posted 05 November 2023 - 05:32 PM
What's your plan for it?
#4 gaspen
gaspen
  • 882 posts
Posted 06 November 2023 - 05:05 AM
I will restore it to original.
#5 gaspen
gaspen
  • 882 posts
Posted 09 November 2023 - 04:00 PM
I think it will be a lot's of fun  :D
Attached File  20231109_155817.jpg   40.38K   1 downloads
It's stamped at the corner of the rubber mat. Do you recognize this supplier ? May I found another one ?
Attached File  20231109_144417.jpg   73.69K   0 downloads
Maybe they fixed that piece with that tape on the assembly line ?
Attached File  20231109_141224.jpg   55.42K   1 downloads
#6 Gilles1000
Gilles1000
  • Just Joined
  • 438 posts
Posted 09 November 2023 - 05:57 PM
Ouch, the rear subby looks nuts... Will you try to repair it ?
How is the body looking around this area ?
Good luck with the project, the car looks nice !
#7 gaspen
gaspen
  • 882 posts
Posted 09 November 2023 - 06:54 PM
Oh it is not so bad, some surface rust...
Did you notice the watershed mountains ?
Attached File  20231109_155553.jpg   63.02K   2 downloads
Attached File  20231109_144521 (1).jpg   71.02K   3 downloads
#8 gaspen
gaspen
  • 882 posts
Posted 10 November 2023 - 07:04 AM
Ouch I don't think so  :lol:  If the front and rear crossmembers could be saved I'll go for it but....
#9 bpirie1000
bpirie1000
  • Area Managers
  • 2,297 posts
  • Local Club: Amoc
Posted 10 November 2023 - 07:22 AM
Rust is lighter than carbon fibre..
Your sitting on a race car there...
But seriously strip it down and give it some time it will return the favour and give you many happy miles.
Sometimes it pays to walk away from the car and put fresh set of eyes on things....
#10 gaspen
gaspen
  • 882 posts
Posted 10 November 2023 - 07:57 AM
For me it is a fun, indeed. But I have to learn when to take a rest  ;D
#11 Viktor
Viktor
  • 653 posts
Posted 10 November 2023 - 01:45 PM
Looks like you are going to have a lot of fun! Good luck with the project, I will be following! :)
#12 gaspen
gaspen
  • 882 posts
Posted 10 November 2023 - 06:14 PM
I can start the work on the body in next spring because I don't have a garage  :ohno:
#13 gaspen
gaspen
  • 882 posts
Posted 14 November 2023 - 07:08 PM
Striptease continued  :D
It looks like the engine was in a machine shop in the past : the cylinders are sleeved and it has 3 camshaft bearings. Until now I thought that a 850 engine has only one bearing on the chain side.
From this point of view the engine is in good shape, but it showed very poor compression when I tested it. See my 1st post.
Any suggestion ?
Attached File  20231114_182223.jpg   35.04K   2 downloads
Attached File  20231114_190221.jpg   65.39K   2 downloads
Attached File  20231114_190235.jpg   31.7K   1 downloads
#14 KTS
KTS
  • 2,392 posts
Posted 14 November 2023 - 07:16 PM
low compression could be piston rings not sealing (worn rings, worn bores or both !), inlet valves not sealing, head gasket failure or a combination of all of them !
#15 gaspen
gaspen
  • 882 posts
Posted 14 November 2023 - 07:23 PM
I will measure and inspect the cylinders later, also the head. The head gasket wast not damaged at all.
