It may tell you the Tpm on the dial at the very bottom of the face almost hidden behind the isn't it shroud.Steve..
Had a look, doesn't appear to be there unfortunately. I've ordered the combo required for the "post '84" since the car is a 1986, hopefully it's right. Fitted them over the weekend with all new gaskets/seals, but obviously can't really test it until the cars on the road. I realised I don't appear to be able to fit the MED crankshaft pulley with the lower engine bracket in place, so I've left that off and just supported the gearbox on some wooden blocks until I'm ready to fit that.
Keeping the progress going, the cars now got all the front suspension refitted and it's back on the ground. It's running Minispares EVO cones and hi-los, finding it's sitting very high and slightly uneven even with the hi-los set to the shortest length. Driver side is 10.5" sill lip to ground and the passenger side is 11.125". I've rolled it back and forth and bounced each corner to try to settle it a bit but that's all it's gone to so far. Is the unevenness a concern? I've checked the cones are seated in the subframe and the hilo, and the hilo is seated into the knuckle joint, it all looks okay. Not completely finished obviously in the photo, just grabbed a shot from ones I took along the way before going round and torquing things up.
Also decided I will fit the 12G295 head, so I took off the existing head to check what type of pistons it has and measure the piston to deck distance, then dropped it off at the machine shop for a good clean up and a slight skim.
I measured 16 thou PTD, so with flat top pistons I make that as needing 24.1cc in the head to achieve 9.75 CR. I didn't have a burette so I've asked the machine shop to measure it and let me know so we can work out how much to take off. It had been skimmed for a standard 998 before when I fitted it to the old car but when I measured it with verniers it'd only had about 30 thou taken off so I don't imagine it was anywhere near that. I've read somewhere that very very roughly 15 thou == 1cc, so that'd put it at about 26.3cc and 9.1CR.
