Edited by HurryUpMiniMetro, 26 October 2023 - 01:46 PM.
Mini Is Randomly Cutting Out And Having An Intermittent Loss Of Power On Acceleration.
Posted 26 October 2023 - 01:43 PM
Posted 26 October 2023 - 03:48 PM
That sounds as though the piston in the carb might be sticking.
Unscrew the big knob on the top of the carb and withdraw the damper. Take the top off the carb, remove the spring and very carefully lift out the piston. Invert the piston somewhere suitable and drain the oil.
Making sure that you take great care of the needle, clean the piston and the inside of the top with a drop of Fairy liquid and Vim (while the wife is at the hairdresser).
Rinse them, dry them, lightly oil them and very carefully re-assemble them. Almost fill the top of the carb with light oil and screw the damper back in.
If that doesn't work, take the bus.
Posted 26 October 2023 - 04:23 PM
I'll have a look at that, I've already been messing around with the dashpot and checking the needle, piston and etc. Just haven't been brave enough yet to separate the dashpot etc.
Posted 26 October 2023 - 07:53 PM
Posted 27 October 2023 - 06:24 AM
https://youtu.be/bYe...2sJWtAaYlAt6H6s
Posted 28 October 2023 - 10:21 AM
I had a local to me (central Scotland) specialist who has AC's training and the session totally transformed the car to the point where it got driven more than it had been
Posted 01 November 2023 - 04:08 PM
Posted 01 November 2023 - 05:47 PM
Edited by cal844, 01 November 2023 - 05:47 PM.
Posted 03 November 2023 - 02:10 AM
It does sound like a carb issue (probably just tuning). It could be an issue at all rpms but you only really notice it at idle as it is really the most sensitive area.
Posted 03 November 2023 - 07:51 AM
The solution was to increase the idle slightly
I have no idea how it reduced the idle speed itself, but that is mini carbs for you.
Posted 03 November 2023 - 08:04 AM
I had this
The idle speed can reduce if the vacuum advance system stops working and the idle timing retards.
Posted 03 November 2023 - 04:36 PM
Posted 04 November 2023 - 11:09 AM
Also tagged with one or more of these keywords: engine, electrical
Mini Technical Sections →
Problems, Questions and Technical →
Clutch Not DisengagingStarted by Sharks , 15 Dec 2024 engine |
Possible Transmission Problem?Started by aguiloco , 07 Dec 2024 engine |
Brake Lights Stopped WorkingStarted by joobs1986 , 04 Dec 2024 brakes, electrical |
Answered
Tachometer Install Drama's/help.Started by Basseyy , 30 Nov 2024 electrical |
Headlights 1974 Mark 3Started by ssyson , 20 Nov 2024 electrical |
