I was wondering if it's E for Export maybe. certainly looks a bit like an afterthought or something someone scratched in later for some reason
850
#31
Posted 04 November 2023 - 05:33 PM
#32
Posted 04 November 2023 - 07:12 PM
I am sure E has some meaning regarding the engine specification but I don't know what.
Here is a plate from a Mini 1000's engine
370089910_716175317041018_3818609812718868947_n.jpg 42.32K
1 downloads
#33
Posted 31 January 2025 - 07:18 PM
Somewhat related....not totally...lol
Was there a 4 synchro "magic wand" shift. If so, which cars...van/picup?
Also...can a 1275 be mounted to one of these gearboxes?
#34
Posted 31 January 2025 - 08:24 PM
They did make a 4 synchro “direct change” which used a remote style diff cover, metal lower plate and a different gearstick. The parts are listed below:
https://www.somerfor...ote-gearchanges
You can also swap an early 3 synchro diff cover onto a 4 synchro remote gearbox case (with all the usual notes on line boring). I did this for my current gearbox and it lined up perfectly without any line boring
Edited by timmy850, 31 January 2025 - 08:27 PM.
#35
Posted 31 January 2025 - 10:53 PM
Mine is a 850 with 4-syncro box, but it is not a "real" magic wand but a modified remote.
How do you call it ?
Microsoft Word - GearboxNumbers_Small.doc
20241201_153405.jpg 41.38K
1 downloads
Edited by gaspen, 01 February 2025 - 09:27 AM.
#36
Posted 01 February 2025 - 10:11 AM
Quote from Somerford Mini:-
"While the direct and remote change systems are very obviously totally different, they share the same gear selector mechanism inside the gearbox. From late 1968 when the gearbox went over from 3 to 4 synchromesh, they shared the same differential housing too - prior to that, the direct gearchange had its own unique diff housing with a small gearchange tower on it."https://www.somerfor...ote-gearchanges
Mk III (1969 – 1976)
The 4 synchro gearbox 22G1128 was introduced in 1968 with magic wand or remote.
However the magic wand version differed from earlier 3 synchro 'magic wand' gear lever gearboxes by using the remote casing, probably as a cost reduction exercise to use one common casing for both types.
Number: 22G1128
Type: 4 Synchro, Magic Wand
Laygear: 22G927
Final Drive: 3.76 Rubber Joint
Applications: Mini 850, Mini 1000 (also Mini Van and Pickup)
Remarks: Used for the very first 85H engines in 1970 where a standard 22G1128 remote casing was equipped with magic wand gear lever by using shaft 88G233 or 88G553 (non-remote
housing), button 2A3467, spring 2A3390 and plate/pad 22A1832. Also confirmed for very late 1969 Mini 1000. Confirmed on original car.
Note: The 4 synchro magic wand gearlever is also different to earlier 3 synchro gear levers, ie. it has the keyway slot in the ball at the top not side.
Also it should be noted the general 'feel' of this later magic wand remote 'conversion' is sometimes not quite as good as the earlier 'dedicated wand 3-synchro diff cover' used for the Mk1 Mini magic wand gear change, especially when any wear is present in the various component parts.
Photo shows parts needed to run the magic wand set up with the remote diff casing.
eg. when a Mk2/3 Four synchro box is used on a mk1
2A3467 Bush
2A3390 Spring
22A1832 Seat / Locating foot
88G553 Selector shaft
22A1717 Cover
22A1382 Gearlever 1968-75 (Later type wand with slot at the top of ball)
3 synchro type (both have slot at the side)
22A91 GEAR LEVER, straight 1959-61.
88G232 GEAR LEVER, cranked 1961-68
Adaptor plate:
Lots more detailed info in this Mk1 forum thread linked below. (You may need to register for access as it is in the 'Technical Talk' section).
Converting a remote box to use Magic wand gear stick:-
https://mk1-forum.ne...php?f=3&p=89542
Edited by mab01uk, 01 February 2025 - 11:22 AM.
