Cardboard Thickness
10 replies to this topic
#1 Cyclops63
Cyclops63
  • 82 posts
Posted 23 October 2023 - 09:16 PM
I've looked across the forum and can't find an answer to this one, although I'm sure many have done it.
What thickness card would be suitable for the rear pocket liners and the dash cards?
#2 greenwheels
greenwheels
  • 684 posts
  • Local Club: Mini Fixers
Posted 24 October 2023 - 09:12 AM
This is probably the best stuff - https://www.woolies-...-1648-millboard
#3 Ethel
  • 25,866 posts
Posted 24 October 2023 - 10:32 AM
See also Foamex - just the first link I found not a recommendation
#4 Cyclops63
Cyclops63
  • 82 posts
Posted 24 October 2023 - 01:12 PM
Jeezo! The card alone is as costly as the properly cut panels....
#5 whistler
whistler
  • 1,786 posts
Posted 24 October 2023 - 01:35 PM
You can find the card in The Range, well I did anyway.
#6 mad4classics
mad4classics
  • 199 posts
Posted 24 October 2023 - 02:50 PM
This is some plain fibreboard https://www.segalmot...?k=:::1867122:0
#7 stuart bowes
stuart bowes
  • 2,046 posts
Posted 24 October 2023 - 03:20 PM
personally I'd probably steer away from fibreboard or anything else that could soak up damp, otherwise over time it'll just rot away and be all floppy and nasty
posts 2+3 probably most appropriate so far but something similarly plasticy would be equally fine, that's the way I'll be going I reckon
Edited by stuart bowes, 24 October 2023 - 03:21 PM.
#8 gaspen
gaspen
  • 908 posts
Posted 21 November 2023 - 07:57 AM
I've choosed foamed PVC for my resto. It is cheap and light, easy to work with.
[attachment=219934:20230312_152743.jpg]
#9 gaspen
gaspen
  • 908 posts
Posted 21 November 2023 - 07:59 AM
sorry, wrong topic :)
#10 humph
humph
    How bad can it Be?
  • 1,088 posts
Posted 21 November 2023 - 01:00 PM
Just a note. The original rear pocket liners on my Riley Elf have a piece of 3mm hardboard glued to the underside of the horizontal section for strength.
#11 growlerbearnz
growlerbearnz
  • 50 posts
  • Local Club: Mini Car Club of Auckland
Posted 21 November 2023 - 07:56 PM
I went for PVC sheet. Strong, light, waterproof, and can be heat formed.
https://63miniresto..../31/door-cards/
