Drive it there early one morning, leave it to cool down for 4 hours or so, do some shopping or whatever and get him to look at it after lunch!l. Especially in winter, it will obviously cool down quick!
There's a ridiculously strong smell of fuel out the exhaust (even with no choke). I even get actual black smoke out the back.
This smell of fuel and black smoke indicates something is wrong with the carb or its setup and it is running too rich as if permanently on choke. This would also result in poor fuel consumption (mpg) and cold running of the engine plus in the longer term piston/bore wear due to oil being washed off the surface of the cylinder bores. Might be worth you overhauling the HIF SU carb or swapping it for a known good replacement with the correct needle, etc.Have you also checked the choke is shutting off fully? At over a 100k miles the carb will likely be in need of an overhaul, clean and a check over for general wear.
Ideally when the cold weather and poor cold running symptoms return you need to take it to the Rolling Road you went to previously and get them to diagnose and pinpoint the problem while it is actually happening.
Back in the day you could have gone to a local breakers and picked up another HIF SU carb off a similar Metro for a reasonable price and then swapped over as a test. Not sure what the going rate on ebay is these days for a good or refurbished HIF44 SU but might be worth a try to eliminate the carb as the problem....
This is problematic because the RR (Peter Burgess) is in Alfreton which is about 30 mins drive from here. By the time I get there, everything will be nicely warmed up and there'll be nothing to diagnose. I guess - in fact I know - there'll be more local RRs, but I know that Pete Burgess is experienced with BL/Leyland stuff, and I'm a bit precious about letting other people tinker with my car :) I'd prefer to only get a known good guy loose on it :)
Definitely am now looking for a replacement HIF44 carb. I've done carb rebuilds myself before, and happy enough stripping down and reassembling with new components. I'm now on the lookout for whatever gets listed on eBay. I've seen that I can get a fully refurbed carb for a hefty price... I don't know how good (or otherwise) the pricey rebuild might be, so I'm looking to find a replacement HIF44 and buy a Burlen rebuild kit. If I get it all sorted, and then take a trip to Peter Burgess to get my overhauled one set up to see if that improves things over winter. Fingers crossed!
I reckon I'm going to have to do exactly this, so he can take a look at the problem when it's actually happening. He's out on an industrial estate in the middle of nowhere. I reckon I'll need to take a book. And a big coat.
Edited by gutted, 02 November 2023 - 04:02 PM.
