My eBay tat gave up today when the shaft snapped and sent a 2" flap wheel, holder and shaft bouncing off the garage walls.
Edited by Gaz66, 02 October 2023 - 08:46 PM.
Posted 02 October 2023 - 08:10 PM
Posted 02 October 2023 - 10:25 PM
Shinano
If you are only using it for roloc discs then get a dedicated roloc sander like an SI2201 or SI2202. 90 degree die grinders are usually more expensive and with less power.
Posted 02 October 2023 - 10:43 PM
Posted 03 October 2023 - 06:41 AM
Machinemart they have a few.
Posted 03 October 2023 - 10:09 AM
You will know when you have bought a good quality one.
Someone will steal it.
Posted 03 October 2023 - 12:33 PM
I have a cheap one that I got off ebay and it has been fine for years and years. As nick says Marchine Marts Clarke brand are usually pretty good.
Posted 03 October 2023 - 02:51 PM
Posted 03 October 2023 - 07:43 PM
Posted 03 October 2023 - 07:47 PM
Just one of several i have had over the years, not a decent name brand (Kobe) and i kicked the living daylights out of that particular one and the straight one as well.
Never seen a snapped shaft like that so must have been a flaw as that shows no sign of deterioration, just a clean break. very weird.
Posted 10 October 2023 - 04:31 AM
It's mainly for roloc discs but when the rough stuff is done it would be nice to fit a velcro pad and use sanding discs.
That would be just like using an angle grinder for fine sanding, a bad idea. They are a rotary movement at over 10,000 rpm.
