Which Water Pump?
9 replies to this topic
#1 johnR
johnR
  • 2,297 posts
Posted 01 October 2023 - 04:12 PM
Is this the best water pump for my 1293 12g940 head pre A plus? The vanes look a bit subliminal compared to some I've seen on MS
#2 imack
imack
  • 2,103 posts
Posted 01 October 2023 - 04:43 PM
I've had good results cooling wise with the minispares evo pump but the bearings didn't last long in it. Refitted my 30+ year old Unipart pump with cast impeller. Appears to work evey bit as well as the evolution pump and the bearings are still good. Recently picked up a NOS Unipart pump for my spares collection.
#3 cal844
cal844
  • 9,622 posts
  • Local Club: TFMOC
Posted 01 October 2023 - 05:17 PM
The only issue I have with the evo pump is the plastic impeller can spin on the shaft and the poor bearing service life (maybe belt tension too tight?)
#4 jpsulisz
jpsulisz
  • Just Joined
  • 57 posts
Posted 02 October 2023 - 05:36 AM
What bearing life are you guys getting?
#5 Cheeser
Cheeser
  • 40 posts
Posted 02 October 2023 - 06:23 AM
John, I wouldn’t use that pump, the impeller is very poor. I use a ‘standard’ minispares pump making sure the impeller is a close fit to the housing, CAREFULLY  press it further on if there is a large tolerance. Suggest you read Calver’s technical notes on cooling on his website.
I run a ‘standard’ MS pump on my 1360 ( about 100 bhp) without problem .
Robin
#6 gav
gav
  • 697 posts
Posted 02 October 2023 - 08:23 AM
The Minispares pumps have a 3 year warranty, if you get an issue please send them back so we can inspect and report any issues.
#7 tarnofsky
tarnofsky
  • Just Joined
  • 35 posts
Posted 02 October 2023 - 09:00 AM
I've run Minispares EVO pumps on all my minis whenever I changed a water pump. I think I bought the first one right after their introduction.
I have them on 998 engines in the Moke and the Clubman Estate, both with bypass, and on the SPI Mini without bypass.
I can't remember since when I've run the first one but I've not experienced any problems so far with any of the pumps.
Just my thoughts here: from my experience there's always some rust and particles in the little pocket under the hole for the water pump in the block. It's like a natural collection place for that, I think. I'm always careful to clean that area completely and prevent the stuff from running through the engine to god knows where. That's why I always remove the water pump whenever the rad has to come out.
When a water pump is out, I suggest you change it no matter what. They are comparatively cheap and considering the hassle of removing the rad to get to it, I recommend to just change it to be on the safe side whenever it's easy to get to it.
#8 johnR
johnR
  • 2,297 posts
Posted 02 October 2023 - 03:26 PM
Robin
Yes, I can't remember where I got that one, but I didn't like the look of it so will scrap it.
#9 Cooperman
  • 23,276 posts
Posted 02 October 2023 - 03:59 PM
I ever only use water pumps with a cast impeller.
#10 Spider
  • 14,838 posts
Posted 02 October 2023 - 05:25 PM
I've been running a Mini Spares EVO Pump for a few years now, off hand it would have done about 25 000 - 30 000 km without issue.
