Fam7821 Brake Limiter Valve - Mounted Upside Down?
brakes
Best Answer tarnofsky , 03 October 2023 - 01:25 AM
FAM7821
Front in         Rear in
Front out                   Rear out
(note the offset rear connections)
Like this ?
Thanks for the picture and port descriptions. I intended to fit the limiter just as in Spider's picture and as per Ethel's description.
So, Ethel, could you please have a look again and confirm that that's how it should be fitted to match your description?
Go to the full post
16 replies to this topic
#16 mbolt998
mbolt998
  • 373 posts
Posted 07 June 2024 - 06:58 AM
FAM7821
Front in         Rear in
Front out                   Rear out
Like this ?
The funny thing is that in OP's picture the hole for the bolt seems to be in a different place. That's why it looks upside-down. The hole's at the bottom even though the top hat bit is on the left.
#17 Ethel
  • 25,919 posts
Posted 11 June 2024 - 11:46 AM
The lines are blurred in the photo, but it does look to be upside down. The relative positions of the pipe connections are what's important - rear outlet closest to one end.
Also tagged with one or more of these keywords: brakes
