Bulkhead Insulation
Posted 26 September 2023 - 04:59 PM
Posted 26 September 2023 - 06:47 PM
I did mine, I did it both inside and outside, the insulation I chose was a Dynamat type, foil backed adhesive foam. This was stuck to the bulkhead, with all other bits lifted out of the way.
IMG_2513.jpeg 102.43K
4 downloads
Under the bonnet, I removed the wiring loom from the clips, fitted the insulation, then re fixed the loom back into the clips.
Being foil backed, it does not look “original” I intend to get the black bulkhead insulation and fit this on top of the foil insulation.
Posted 26 September 2023 - 10:12 PM
How much noise difference did it actually make
Posted 26 September 2023 - 11:02 PM
Posted 28 September 2023 - 08:26 AM
wiring and everything else ontop of insulation, easier maintenance and tidier
Posted 28 September 2023 - 09:53 AM
And make sure it's a tight fit, right up to the edges and corners. Any gaps and the noise will get through.
Posted 30 September 2023 - 09:52 PM
Thinking of fitting engine side bulkhead insulation is it best above the wiring or the wiring on top of insulation
I recently fitted some on mine. I removed everything from the bulkhead, made a cardboard template and then transferred that to the material I was using. Everything was then refixed to the bulkhead with the insulation in between so everything is still accessible like normal.
I used Dodo Barrier Pro which is a dual layer sheet of closed cell foam coupled with a layer of mass loaded vinyl with the CCF against the bulkhead and the MLV on the outside.
It was a long job to do it all but I'm pleased with the results as it looks neat and like something the factory should have fitted.
Posted 01 October 2023 - 08:42 AM
Posted 01 October 2023 - 10:12 AM
Posted 01 October 2023 - 02:31 PM
Since I have insulated the bulkhead I am unable to hear the indicator relay! I thought is had gone silent, but can hear it clicking away with the bonnet open, I can just hear it in the car without the engine running.
on the move it can’t be heard!
